Old 02-28-2018, 12:43 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Newly installed Apexi EXV N1 coilovers clunk noise when car’s cold
Notice this for a few days now after the install. I can hear clunk noise from rear suspension when turning in slow speed or going over a speed bump. However, the noise subdued after driving for a while. Is this normal? I had mine installed at a reputable shop I’ve been going for almost 10 years.
stlgrym3 is offline   Reply With Quote
Old 02-28-2018, 02:40 AM   #2
tyler_win_photo
tyler_win_photo's Avatar
Could be anything really. Try re-torquing everything.
tyler_win_photo is offline   Reply With Quote
Old 03-02-2018, 01:04 PM   #3
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Mine do the same thing. If you’re running solid top mounts like I am, I believe it is actually just the spherical bearing shrinkage due to it not being warm enough. Not sure how familiar you are with metallurgy but when metals are cold they shrink, and when they heat up the expand. The little bearing the shock fits into on the mount will shrink in diameter, thus allowing it to move up and down slightly inside the race. Thats my theory, as I don’t know what else it could be.
I wouldnt worry too much about it. Solid mounts are usually pretty noisy at low speed because race car.
Be careful with hitting large bumps in the road too fast, it can really mess up those bearings
idkwhatimdoing is offline   Reply With Quote
Balance newly installed tires/rims golemslord Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-15-2016 05:44 PM
Newly installed problems JG Engine, Exhaust, Transmission 16 06-27-2015 11:33 AM
Cold Start Clunk Noise Luckrider Issues | Warranty | Recalls / TSB 6 11-28-2013 05:02 PM
Feedback through newly installed tweeters mit_peid Electronics | Audio | NAV | Infotainment 24 04-07-2013 10:05 AM
