Old 02-25-2018, 02:37 AM   #1
MyGT86Yas
Drives: 2017 WRB BRZ
OFT throttle response
I’m sure I saw a topic about this before but I couldn’t find it. So after the loading the latest version stage 2+ E85 flash (2017 Brz), I notice a big difference of throttle responsiveness compare to stock, especially when trying to accelerate from stop. Like the gap from where the gas pedal sits to where the “actual gasing” point got bigger. Is it a common thing and is there a solution?
MyGT86Yas is offline   Reply With Quote
Old 02-25-2018, 02:51 AM   #2
KevlarZN6
Drives: 13 Toyota 86~ 72 Rb26 240z
When ever you flash the ECU or disconnect the battery, the ECU has to relearn the pedal. I believe theres steps to get it relearned or you can drive it and it'll relearn by itself after a few miles....Now if you still have the problem after the ECU has relearned it, then theres probably a slight hiccup on the tune file.
KevlarZN6 is offline   Reply With Quote
Old 02-25-2018, 09:59 AM   #3
Bkdshadow
Drives: 2013 Scion FRS
Yep pretty much what Kevlar said. I saw some people saying to turn the accessories on and press in the gas pedal in and out like 30 times to help the car relearn. I tried this myself and personally didn’t think it helped (felt the dead zone like you)
Don’t worry though, it will go away and feel better after some driving. Mine took around 60ish miles before the deadzone was completely gone
Bkdshadow is offline   Reply With Quote
Old 02-25-2018, 10:11 AM   #4
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Exactly what's been said before me. When I flash a new tune with the oft, there's some "play" in the actual accelerating point in the gas pedal. I usually drive for at least 30 minutes and it becomes more responsive the more I go along.
KMA KiCKz is offline   Reply With Quote
Old 02-25-2018, 12:31 PM   #5
Decep
Drives: 2013 FR-S Series 10
For me, i usually have to drive 100-150 miles of easy cruising. Then after that, go to full throttle at a lower gear (maybe 2nd) and then your pedal should come back.
Old 02-26-2018, 12:13 AM   #6
MyGT86Yas
Weird, it just disappeared today all of a sudden lol
Old 02-26-2018, 05:44 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
How is that weird, it's exactly as they said it'd be
Improve throttle response ChrisD BRZ First-Gen (2012+) — General Topics 80 10-05-2020 07:50 PM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Throttle Response when Rev Matching JohnAyySays Issues | Warranty | Recalls / TSB 11 11-15-2013 10:56 AM
poor throttle response Djen Electronics | Audio | NAV | Infotainment 5 06-18-2013 07:31 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
