Old 06-18-2013, 05:12 PM   #1
Djen
Drives: GT86
poor throttle response
hi could someone help me step by step.. dose someone experience same what I do ?
I just installed CAI and I drive it for half an hour then I disconnect the nagtive battry tinrmal for 20min and then put it on agine I allowed the ECU to reset so the rexults now a Poor acceleration\slow throttle response.. please could someone help me out
Djen is offline   Reply With Quote
Old 06-18-2013, 05:26 PM   #2
cruzinbill
Drives: Argento 6spd FR-S
you are gonna have to wait till the ecu relearns. it takes a lil while after resetting the ecu. just drive it... it will return to normal
cruzinbill is offline   Reply With Quote
Old 06-18-2013, 06:24 PM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
What cruzinbill said, just drive it like you normally do. The ECU will re-learn and your throttle response will return to how it was. This is common with a lot of drive by wire cars I've driven.
G_Ride is offline   Reply With Quote
Old 06-18-2013, 06:53 PM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
It will take time for the car to adjust...
Old 06-18-2013, 07:04 PM   #5
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
This.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 06-18-2013, 07:31 PM   #6
Pete
Pete's Avatar
Drives: 22 BRZ
1. turn the key to "on" without starting the car
2. press the gas all the way to the floor then raise it all the way up. Do this 20 times.
3. turn key to off, wait 1 second then turn the key back to "on" without starting the car
4. press the gas all the way to the floor then raise it all the way up. Do this 20 times.
5. turn key off, then start the car
This gets rid of dead pedal in a few minutes instead of days.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
poor throttle response Djen Engine, Exhaust, Transmission 21 06-14-2014 01:22 AM
Throttle response delay jay07631 Engine, Exhaust, Transmission 12 07-09-2013 09:41 PM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
