Drives: 2013 Supercharged BRZ, E85, Ohlins
3D printed "Deep Dish" Fuse panel cover
Like many others I use add-a-fuse taps in my under-dash fuse panel. The taps are large enough that the OEM fuse panel cover no longer closes. This can expose the fuse panel to the driver's shoes and whatever might be on them water, mud,snow, etc). Not ideal.
So I designed a deep-dish fuse panel cover that replaces the original. The attached obj file can be run out of any 3D printer to produce a decent replacement cover with an extra inch of clearance inside, plus side cutouts for cables etc. This fits great on my 2013 BRZ. I have not tried it on other cars, so Your Mileage May Vary (No gaurantees). Feel free to take the obj file and modify it. Fit can be adjusted with sanding or electrical tape as necessary. You may want to notch the sides out wider depending on number/location of fuse taps. The fuse diagram is from the BRZ wiring guide pdf you can find on this forum. Pics: Zip file with the obj: FuseBoxCover04.zip FYI you can print these through any FDM printer. I belive some HomeDepot stores and some public libraries have 3D printers for rent. You can also use the shapeways.com printing service if you upload the obj file. I used file2fab in Santa Monica. Paul was very helpful and turned the job around in a day. Prints should cost around $25 dep on provider and material used. A final disclaimer: This is my amateur work. It worked fine on my 2013MY with a little sanding of the clips, but I don''t gaurantee it will work flawlessly for you. I'm not selling anything. Take & use the model for free. Have fun with it! |
| The Following 15 Users Say Thank You to canyons For This Useful Post: | BirdTRD (02-23-2018), BriRZed (09-14-2022), Chaetagnath (02-24-2018), Chimera (02-23-2018), Code Monkey (02-26-2018), Dadhawk (02-27-2018), DAEMANO (02-23-2018), ichitaka05 (02-26-2018), JeremyR (02-27-2018), n0thing (02-25-2018), Sapphireho (02-26-2018), Stang70Fastback (02-23-2018), Tcoat (02-27-2018), Ultramaroon (02-24-2018), zeal86 (02-23-2018) |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Wow this looks great. Wish I could buy one!
not playing cards
Crazy! I'm in the middle of installing my first add-on this weekend. Just figured I would throw the OEM cover into the glove box and leave it at that. Thanks for an elegant solution.
Site Moderator
Drives: ichi 86 Project
Huh, this is creative! Good job on this awesome idea and thanks for sharing the file!
Famous Potatoes
Drives: '15 ultramarine
Good thinking!
A.K.A. Starlord
Drives: 2015 Series.Blue
Great idea. I chose the "lazy" solution, lol.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Tcoat (02-27-2018) |
#10 |
Site Moderator
Zip ties and duck tapes are men's best friend
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Tcoat (02-27-2018) |
#11 |
not playing cards
Looks stock.
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | Dadhawk (02-27-2018), JimmyMac (03-01-2018), JoeC (02-27-2018), Stang70Fastback (02-26-2018), Tcoat (02-27-2018) |
#12 |
The proper phrase is "This is how it should have come from the factory".
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JimmyMac (03-01-2018), Ultramaroon (02-27-2018) |
#13 |
mine worked out great
| The Following 4 Users Say Thank You to Elliotw For This Useful Post: |
| Tags |
| fusebox |
| Running light "Tail" fuse in foot well keeps blowing **Fixed** | paintdude258 | Electronics | Audio | NAV | Infotainment | 0 | 04-12-2017 03:59 PM |
| Deep "scratch" on back bumper - How bad $$? | carsebuco | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 16 | 01-12-2017 10:23 PM |
| Deep dish or na? | tooslow4umayne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 10-21-2016 11:07 AM |
| Open "power with key" slot in fuse box | Ashikabi | Electronics | Audio | NAV | Infotainment | 0 | 09-15-2015 10:52 PM |
| 15" ultra deep dish wheels. | Yamajee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 02-26-2015 03:19 PM |
