Old 04-12-2017, 04:59 PM   #1
paintdude258
paintdude258's Avatar
Running light "Tail" fuse in foot well keeps blowing **Fixed**
Hey guys,
I just ran into quite the scenario that caused me a couple of new gray hairs.
I had a fuse in my driver side footwell continue to blow each of the dozen or so times I tried to replace it. My running lights (Boomerang, taillights, turn lights, and license plate lights) would work for a minute or two, and then the fuse would blow again.
I checked all 8 bulbs affected by the short, but all were working perfectly.
I dissected the wiring in my trunk first. Then moved to my turn lights. I tried switching out my tail lights for my OEM ones, but nothing helped.
Last to check was my boomerangs. I found the wiring diagram online and found that the boomerang light wire that goes in and out of the headlight is lime green, so I focused on tracing that wire from source to source.
Turns out, I have a @Mishimoto oil cooler installed on my car that i absolutely love, but the braided line that runs into the front of my bumper to supply oil to the intercooler had actually moved and made contact with the green wire that powers my boomerang.
The oil cooler must be grounded, causing my boomerang wire to be shredded and then grounded.
When I found the problem, I jumped around and screamed with joy in the middle of a gas station.
Problem solved.
I doubt many have run into this problem, but just in case, this is a good starting place to look for such a problem.
Blake
paintdude258 is offline   Reply With Quote
mishimoto, oil cooler
Open "power with key" slot in fuse box Ashikabi Electronics | Audio | NAV | Infotainment 0 09-15-2015 11:52 PM
Bluetooth connection "fixed" 2014 Limited snodgrass Electronics | Audio | NAV | Infotainment 4 04-23-2014 02:58 PM
Crystal Eye Tail light "Europe Mod" Trap63 EUROPE 1 05-03-2013 04:00 AM
Anybody making a tail light "T connector"? Trashed675 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-08-2013 09:44 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
