Old 02-23-2018, 07:00 PM   #1
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
3D printed "Deep Dish" Fuse panel cover
Like many others I use add-a-fuse taps in my under-dash fuse panel. The taps are large enough that the OEM fuse panel cover no longer closes. This can expose the fuse panel to the driver's shoes and whatever might be on them water, mud,snow, etc). Not ideal.
So I designed a deep-dish fuse panel cover that replaces the original. The attached obj file can be run out of any 3D printer to produce a decent replacement cover with an extra inch of clearance inside, plus side cutouts for cables etc.
This fits great on my 2013 BRZ. I have not tried it on other cars, so Your Mileage May Vary (No gaurantees). Feel free to take the obj file and modify it.
Fit can be adjusted with sanding or electrical tape as necessary. You may want to notch the sides out wider depending on number/location of fuse taps.
The fuse diagram is from the BRZ wiring guide pdf you can find on this forum.
Pics:
Zip file with the obj:
FuseBoxCover04.zip
FYI you can print these through any FDM printer. I belive some HomeDepot stores and some public libraries have 3D printers for rent. You can also
use the shapeways.com printing service if you upload the obj file. I used file2fab in Santa Monica. Paul was very helpful and turned the job around in a day. Prints should cost around $25 dep on provider and material used.
A final disclaimer: This is my amateur work. It worked fine on my 2013MY with a little sanding of the clips, but I don''t gaurantee it will work flawlessly for you. I'm not selling anything. Take & use the model for free. Have fun with it!
canyons is offline   Reply With Quote
The Following 15 Users Say Thank You to canyons For This Useful Post:
BirdTRD (02-23-2018), BriRZed (09-14-2022), Chaetagnath (02-24-2018), Chimera (02-23-2018), Code Monkey (02-26-2018), Dadhawk (02-27-2018), DAEMANO (02-23-2018), ichitaka05 (02-26-2018), JeremyR (02-27-2018), n0thing (02-25-2018), Sapphireho (02-26-2018), Stang70Fastback (02-23-2018), Tcoat (02-27-2018), Ultramaroon (02-24-2018), zeal86 (02-23-2018)
Old 02-23-2018, 09:02 PM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
That's OK, I'm sure one of the vendors will jump on this, put a logo on it and sell them for $86.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Chimera (02-24-2018)
Old 02-24-2018, 01:28 PM   #3
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Wow this looks great. Wish I could buy one!
Elliotw is offline   Reply With Quote
Old 02-24-2018, 01:54 PM   #4
Crazy! I'm in the middle of installing my first add-on this weekend. Just figured I would throw the OEM cover into the glove box and leave it at that. Thanks for an elegant solution.
Old 02-25-2018, 05:00 PM   #5
canyons
canyons's Avatar
There have to be 3D printing services in Seattle? Or mail-order it from shapeways.com .... Just give them the obj file I attached above.
The Following User Says Thank You to canyons For This Useful Post:
Elliotw (02-26-2018)
Old 02-26-2018, 03:49 PM   #6
Elliotw
Elliotw's Avatar
Gonna give shapeways a try. Thanks
Old 02-26-2018, 04:25 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Huh, this is creative! Good job on this awesome idea and thanks for sharing the file!
Old 02-26-2018, 04:29 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Good thinking!
Old 02-26-2018, 04:57 PM   #9
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Great idea. I chose the "lazy" solution, lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (02-27-2018)
Old 02-26-2018, 05:02 PM   #10
ichitaka05
Site Moderator
ichitaka05's Avatar
Zip ties and duck tapes are men's best friend
Tcoat (02-27-2018)
Old 02-26-2018, 09:11 PM   #11
Looks stock.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
Dadhawk (02-27-2018), JimmyMac (03-01-2018), JoeC (02-27-2018), Stang70Fastback (02-26-2018), Tcoat (02-27-2018)
Old 02-27-2018, 11:47 AM   #12
Looks stock.
The proper phrase is "This is how it should have come from the factory".
JimmyMac (03-01-2018), Ultramaroon (02-27-2018)
Old 03-08-2018, 07:00 PM   #13
Elliotw
Elliotw's Avatar
mine worked out great
The Following 4 Users Say Thank You to Elliotw For This Useful Post:
canyons (01-17-2023), chaoskaze (08-01-2018), Dadhawk (03-09-2018), Ultramaroon (03-08-2018)
fusebox
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 03:59 PM
Deep "scratch" on back bumper - How bad $$? carsebuco Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 01-12-2017 10:23 PM
Deep dish or na? tooslow4umayne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 10-21-2016 11:07 AM
Open "power with key" slot in fuse box Ashikabi Electronics | Audio | NAV | Infotainment 0 09-15-2015 10:52 PM
15" ultra deep dish wheels. Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 02-26-2015 03:19 PM
