Old 02-23-2018, 12:58 PM   #1
ort895
ort895's Avatar
I can't tell what happened here
At first i thought somebody had put out a cigarette on my bumper, but as you can see the bumper has a crease in it so somebody backed into me?
Either way, is this a simple fix or would this require me replacing the bumper?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 02-23-2018, 03:09 PM   #2
humfrz
Oh, that's nasty......
You might consult with a PDR person for the dent.
Some touch up paint would make the "spots" look better.
Rubbing compound may take out the other marks.
humfrz
ort895 (02-23-2018)
Old 02-23-2018, 06:18 PM   #3
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Looks like someone bumped it and the rear crash beam was trying to come out from the other side PDR wont fix that. Bumper replacement or body work will fix it.
thatfilipinoguy is offline   Reply With Quote
The Following 3 Users Say Thank You to thatfilipinoguy For This Useful Post:
ort895 (02-23-2018), Tcoat (02-24-2018), Zentec (02-24-2018)
Old 02-23-2018, 06:25 PM   #4
ort895
ort895's Avatar
ahh i see that now. Thanks
Old 02-24-2018, 03:12 AM   #5
Zentec
Drives: 2017 Toyota 86
Yep needs to be replaced
Zentec is offline   Reply With Quote
Old 02-24-2018, 10:06 AM   #6
I don't think this was a gentle bump, given the cover has protrusions from the inside out. Check your hood lines, if they aren't even you may have more damage than you think. the corner fender supports are not very substantial and twist easily (from experience). You may also have some damage on the crash bar if that is what caused this.
Tcoat (02-24-2018)
Old 02-24-2018, 02:06 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
in 4 partout
Old 02-24-2018, 02:43 PM   #8
Yep. Those "Swirls" above the hole are stress cracks. It actually got hit pretty hard. You will need to see what is going on in behind there.
Dadhawk (02-24-2018), ort895 (02-24-2018)
Old 02-24-2018, 08:30 PM   #9
ort895
ort895's Avatar
Thanks for the input guys. I will definitely get it looked at by a local shop.
Old 02-26-2018, 03:52 PM   #10
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
doesn't need to be replaced. just repaired and painted
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 02-26-2018, 03:58 PM   #11
What would be used to repair the plastic?
Old 02-26-2018, 04:01 PM   #12
spitfire481
Drives: 2JZ FRS
strip the paint around it, heat and press flat. then 3M plastic repair filler to skim over then sand smooth. about an hour and a half body labor, not much to it.
MoTeC
Build Thread
@spitfire481
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
Dadhawk (02-26-2018), DAEMANO (02-26-2018), ort895 (02-26-2018), Tcoat (02-26-2018)
Old 02-26-2018, 04:03 PM   #13
Good to know! I have personally never had plastic parts repaired so wasn't sure how it would be done. Would always be concerned that the flex in the plastic would make filler pop out but if there is stuff made just for that I would think it would be fine.
Old 02-27-2018, 01:58 AM   #14
humfrz
It's not the Bondo of back in your body repair days .......
Besides ...... he doesn't have to do the WHOLE car ......
humfrz
Tcoat (02-27-2018)
Well this happened rosol16 BRZ First-Gen (2012+) — General Topics 36 01-05-2016 03:02 AM
So, this happened. Jonesy86 Northwest 30 12-25-2015 07:36 PM
so this happened... scottxnizzle BRZ First-Gen (2012+) — General Topics 19 07-24-2015 04:03 PM
It has happened. TnRen41 Scion FR-S / Toyota 86 GT86 General Forum 44 03-10-2015 11:41 PM
Has this happened to anyone else.... FR-S Hot Lava Issues | Warranty | Recalls / TSB 5 06-03-2013 11:28 AM
