| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
I can't tell what happened here
At first i thought somebody had put out a cigarette on my bumper, but as you can see the bumper has a crease in it so somebody backed into me?
Either way, is this a simple fix or would this require me replacing the bumper?
Yeah its an auto, deal with it.
#2 |
Oh, that's nasty......
![]() You might consult with a PDR person for the dent. Some touch up paint would make the "spots" look better. Rubbing compound may take out the other marks. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ort895 (02-23-2018) |
#3 |
Drives: 87 Supra, 13 FRS, 05 FXT
Looks like someone bumped it and the rear crash beam was trying to come out from the other side PDR wont fix that. Bumper replacement or body work will fix it.
#4 |
ahh i see that now. Thanks
#5 |
Drives: 2017 Toyota 86
Yep needs to be replaced
#6 |
I don't think this was a gentle bump, given the cover has protrusions from the inside out. Check your hood lines, if they aren't even you may have more damage than you think. the corner fender supports are not very substantial and twist easily (from experience). You may also have some damage on the crash bar if that is what caused this.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (02-24-2018) |
#7 |
in 4 partout
#8 | ||
#9 |
Thanks for the input guys. I will definitely get it looked at by a local shop.
#10 |
Drives: 2JZ FRS
doesn't need to be replaced. just repaired and painted
#11 |
What would be used to repair the plastic?
#12 |
Drives: 2JZ FRS
strip the paint around it, heat and press flat. then 3M plastic repair filler to skim over then sand smooth. about an hour and a half body labor, not much to it.
#13 |
Good to know! I have personally never had plastic parts repaired so wasn't sure how it would be done. Would always be concerned that the flex in the plastic would make filler pop out but if there is stuff made just for that I would think it would be fine.
#14 | |
![]() Besides ...... he doesn't have to do the WHOLE car ...... ![]() ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (02-27-2018) |
| Well this happened | rosol16 | BRZ First-Gen (2012+) — General Topics | 36 | 01-05-2016 03:02 AM |
| So, this happened. | Jonesy86 | Northwest | 30 | 12-25-2015 07:36 PM |
| so this happened... | scottxnizzle | BRZ First-Gen (2012+) — General Topics | 19 | 07-24-2015 04:03 PM |
| It has happened. | TnRen41 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 03-10-2015 11:41 PM |
| Has this happened to anyone else.... | FR-S Hot Lava | Issues | Warranty | Recalls / TSB | 5 | 06-03-2013 11:28 AM |
