Old 02-19-2018, 08:10 PM   #1
Alfrz91
Drives: 13 Scion Frs
Alignment after getting new tires, was this even necessary?(Pic included)
Slapped some new tires on and they recommended an alignment. My old tires wore extremely evenly, but I figured what the hey, new tires, don't wanna cheap out here. When the alignment report came back though... (which I'm just now taking a peek at when I got home) feel like they should've just said, nah you're good.
What do you think?
Alfrz91 is offline   Reply With Quote
Old 02-19-2018, 08:35 PM   #2
CoolHandMoss
Drives: 2013 FRS
You should have gotten them to match the driver's side camber to the passnger's side while they did it to make it worth while.
At least they fixed the front toe up.
But yeah, wasn't worth doing. There was no indication that the alignment was off to begin with and they were just drumming up business.
CoolHandMoss is offline   Reply With Quote
Old 02-19-2018, 09:07 PM   #3
strat61caster
strat61caster's Avatar
Depends on what they charged and how much you care about the nitty gritty of how your car performs. I'd be totally satisfied to spend $100 on that alignment, much more and it'd be a ripoff. But I care about how the car is aligned to an insane amount, if it was a commuter car then yeah I'd feel like I wasted some time/money.
Also your shop is lazy for not measuring caster.
ineedyourdiddly
Old 02-20-2018, 10:36 AM   #4
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
They might have got one over on you there. There's only so much that can be done on stock parts and that rear right being different than the left camber is pretty normal. They don't check it with you in it and when you sit in it it may be closer to even. .13 front right toe isn't a big deal but being even is always better.
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-20-2018, 11:08 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
They did get rid of your toe as pointed out. But yea more or less waist of money. I would of asked them to add some camber to the front and match the front left and right but it is what it is.
This is why I don't take my car to chain stores...
jasonojordan is offline   Reply With Quote
Old 02-20-2018, 11:14 AM   #6
wparsons
wparsons's Avatar
Camber isn't adjustable with stock parts, so there's nothing they could've done to even out the camber at all.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Leonardo (02-20-2018)
Old 02-20-2018, 11:39 AM   #7
Racecomp Engineering
I'd be disappointed in that alignment, but that's just me.
- Andrew
Old 02-20-2018, 12:19 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Does the shop offer a warranty of any kind? I would take it back til they fixed my rear toe too.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Racecomp Engineering (02-20-2018), strat61caster (02-20-2018)
Old 02-20-2018, 12:19 PM   #9
Teseo
Drives: frs
- Andrew
Its posible you can lrovide "ideal" alignment picture like op? With that i can bring it to my tech so he can work to achieve such numbers
Teseo is online now   Reply With Quote
Old 02-20-2018, 12:32 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
If you get a generic alignment for a car, you cannot expect them to do *anything* more than get you "all green".
More people need to be aware that:
1. You don't need an alignment with new tires
2. Factory adjustments on this car are limited to front and rear toe
3. Factory specs are a very broad range
If you're getting a generic alignment on this car, you should not be paying much for it because you won't be getting much *if anything* out of it.
The Following 5 Users Say Thank You to ZDan For This Useful Post:
finch1750 (02-20-2018), Racecomp Engineering (02-20-2018), strat61caster (02-20-2018), Teseo (02-20-2018), wparsons (02-20-2018)
Old 02-20-2018, 12:45 PM   #11
finch1750
finch1750's Avatar
Depending on the shop, asking for a certain spec like 0 toe sometimes goes a long way to get better the -.08 and .1 side to side though.
But is very tech/shop dependent so YMMV, but it never hurts to ask
Racecomp Engineering (02-20-2018), wparsons (02-20-2018)
Old 02-20-2018, 12:54 PM   #12
A good alignment is driver and car dependent. This requires a good shop.
But for a completely stock 86, there aren't a lot of adjustments to make. Just zero the toe to make things simple.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Old 02-20-2018, 01:28 PM   #13
CoolHandMoss
Drives: 2013 FRS
I realize. But it can be made that way. But that's not what the question was about.
Old 02-20-2018, 03:45 PM   #14
Alfrz91
Thanks for all the replies, the car IS entirely stock and it was from a dealership. Normally I wouldn't have even gotten the alignment but the tech seemed like a solid cut and I actually came back to look it up while they were putting the tires on and I found a few recommendations for it. All that being said, I'm very far from being an expert but I've seen alignment reports before and this just seems like such a waste of money/ time for an incredibly small gain... if any. I've no problem going back and having them take another crack at it/refund (if it does in fact seem like they shouldn't have done it/known better/done more/etc), as in my experiences any place that works on a car will always try to make it right if they can.
New wheels/tires=alignment X Factor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-14-2015 09:20 PM
Oddities: new alignment, tires and wheels rainmonkey Tracking / Autocross / HPDE / Drifting 12 10-25-2013 09:29 PM
FS (south florida)- 4 wheels + tires, TPMS included $300 OBO sieeegel Wheels and Tires 6 08-23-2013 05:12 PM
FS: factory FRS wheels and tires (TPMS sensors included!) cb7tuner Wheels and Tires 1 08-16-2013 01:26 AM
FEELER: 18x8 +35 5x100 Ace Vertex - tires included ayetothejay Wheels and Tires 1 02-17-2013 08:07 PM
