Old 02-12-2018, 10:09 PM   #1
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
Alignment Question
Hey everyone looking for some alignment advice for my car. I'll most be driving Sonoma this year with some events at Thunderhill and Laguna thrown in as well.
With driver the car weighs 2872
List of current modifications I have
APR Front Splitter
APR GTC 200 Wing
Stance XR2 (Double Adjustable-Cannot find spring rates)
Perrin Front Sway Bar 19mm
WRX Rear Sway Bar 16mm
SPC Rear LCA
Rear Crossmember Bushing
17x8 wheels with 245/40/17 BFG R1
Not looking for an exact number, more just an area to start the settings off at and then adjust accordingly.
Check out my racing adventures on
@omi_racing on Instagram!!
2013 Scion FR-S//2015 Aluminos CRF 250R Kart//2009 CRG Briggs and Stratton Kart
http://www.ft86club.com/forums/showthread.php?t=119147
Tofurky is offline   Reply With Quote
Old 02-12-2018, 10:15 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
-3/-2 zero toe. Adjust to even temps.
Old 02-12-2018, 11:09 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
Looking for even wear and long lasting tires? Then the sugestion above is sound. Looking for the fastest possible time? Then even temps is not what you are looking for and -3/-2 is almost always too little to start with.
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
cjd (02-13-2018), strat61caster (02-12-2018)
Old 02-12-2018, 11:29 PM   #4
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
Any suggestions on a range?
Old 02-13-2018, 12:25 AM   #5
FirstWinter
Drives: Car
Depends on your preferences as a driver, setup, and course layout. This is going to be purely a track car running in ST5 right? I would use a tire pyro and mess around until you find something that works for you. If you're mostly running Sonoma and in a certain direction each side would be set differently as well as the corner balancing of the car.
Could start with Front: -3.3 Rear: -2.7. Could do a little toe out up front and some toe in rear. I haven't had aero on my car so I'm not sure how alignment would work with that. Keep notes & data and adjust accordingly.
FirstWinter is offline   Reply With Quote
Old 02-13-2018, 09:53 AM   #6
Icecreamtruk
Plenty of suggestions thrown around but as it has been mentioned, it depends on driver style and conditions. Instead of throwing numbers out there, I'll just tell you what you are looking for in a pyro reading to know when you have the right settings. Basically, you dont want even temps for fast laps, thats for more or less even wear. For fast laps you need camber that maximize grip on turns, and that will read out as an even spread of temp with the hotter inside and cooler outside. An example of a good spread would be 170 outside, 175 middle, 180 inside. An example of a tire wit too much camber would be 165 outside, 170 middle 180 inside. An example of a car with too little camber would be even temps or close to, like 175 outside, 175 middle, 180 inside.
Unless you already drive at the maximum available grip in turns, which very few people do (im not one of those), as your turning speed increases, so will the roll in your car, and so the amount of camber needed will change. So even after you found your current sweet spot, that will change over time so keep an eye out for that.
Edit: also see no mentions of toe. Basically im a preacher of 0 toe in the rear and 0 or minimal toe-out in the front. Toe scrubs speed and wear tires faster, and most people doing toe-in in the rear are trying to compensate for a loose car. After putting a GT-wing in, a loose rear is no longer a problem, its rather making it turn that becomes a challenge.
Old 02-13-2018, 01:25 PM   #7
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Is this strictly for track or is it a daily driver too? Because using a dedicated track alignment on the street isn't going to be much fun.
smg1138 is offline   Reply With Quote
Old 02-13-2018, 10:46 PM   #8
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
ST5 race car
Old 02-14-2018, 11:34 AM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I would imagine your first priority is to figure out why some very competent alignment shops couldn't get more then -1.7 with RLCA. I had over -2 just from 1" lowering springs and no adjustment.
Old 02-14-2018, 11:54 AM   #10
FirstWinter
Drives: Car
The SPC LCA he has aren't like other adjustable RLCA. It uses an eccentric bushing but even then it should still get a bit more. I think the reason why he isn't getting more just from looking at his pictures is his rear is pretty high.
@Tofurky Maybe if you tried lowering the rear more it would help. Is there a reason why you're running that much rake in the first place?
Old 02-14-2018, 12:01 PM   #11
finch1750
finch1750's Avatar
Originally Posted by FirstWinter View Post
The SPC LCA he has aren't like other adjustable RLCA. It uses an eccentric bold but even then it should still get a bit more. I think the reason why he isn't getting more just from looking at his pictures is his rear is pretty high.
I'm currently running SPC as well and have not had issues getting -2.5. Didn't know he was running a lot of rake though. I am dropped 1-1.5" currently
Old 02-14-2018, 12:24 PM   #12
Icecreamtruk
SPC LCA comes with a eccentric bushing that is pressed in to allow for more or less camber depending on how you put it in. Mine is put to allow for more and the lowest I can go at stockish ride height and 0 toe is -2.8. Lowered around 1inch that goes to like -3.2. I think in OPs case that bushing was pressed in the other way, to reduce camber.
Alignment question. ohnoitsthefuzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-09-2015 07:33 AM
Alignment Question Covo_86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-04-2014 11:37 AM
Alignment question? cjsporl1996 Tracking / Autocross / HPDE / Drifting 13 05-12-2014 04:00 PM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 09:23 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 12:52 PM
