Old 02-11-2018, 02:41 PM   #1
J41v33
Drives: fr-sexy
Exclamation Jacks transmission rebuild service
Has anyone sent a transmission to Jacks Transmissions to get theirs rebuilt?
Im having issues with my 4th gear grinding at anything above 5.5k rpm, and I’m afraid it will just get worse from there. Sometimes 3rd and 5th gear will grind a little during up shifts too, doesn’t matter what The rpms are at. Only mods I have is oft uel stage 2, shifter springs, white line transmission insert, and catback exhaust.
The car was bought used with 30k miles and the transmission fluid was swapped to motul gear 300 at 32k, again at 60k, and again at 75k
4th gear only started acting up at 65k. My car is at 80k so I’m out of warranty so bringing it into the dealership is out of the question. A friend that works at the dealership said it’s about 6,000 for a new transmission installed.
I’m trying to see if the rebuild service offered by jacks is worth it, how is the rebuild holding up, and how is their customer service. I’m planning to buy a used broken transmission and sending that in to get that fully rebuilt so at least I have a car to get to work.
Any help is appreciated.
J41v33 is offline   Reply With Quote
Old 02-11-2018, 06:01 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Have you tried switching from motul to redline oil? Might be a cheaper option for the meantime
Old 02-12-2018, 02:45 AM   #3
Zentec
Drives: 2017 Toyota 86
I would have suggested that if he didn’t already change it a couple of times. Don’t waist your time or money on changing the fluids.
I have not heard about any rebuilds from them. I would compare the price of a rebuild and possibly have the same issue down the road or see if you can get the2017 transmission it dosnt have the issue I would also upgrade the diff to the 2017 as well as it has a better final drive.
Zentec is offline   Reply With Quote
Old 02-12-2018, 06:06 AM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
He said he used the same fluid 3 times. I think....
Any who you can try and save a few bucks by taking the tranny out yourself. Or maybe you can find a cheap on from a wrecked car.
Old 02-16-2018, 09:14 AM   #5
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
I've been running a Jack's rebuilt for the past 2 years (2 racing seasons). Went this route after destroying 2 transmissions in the hopes it would last longer.
I've been testing prototype parts for them and couldn't be happier. My trans is at their shop right now being upgraded with the carbon synchros and some other stuff.
Costumer service is top notch and they stand behind their products 100 percent.
Having said that, Trans have gone down in price a lot. It depends on what you do with the car.
For me, longevity and buttery shifting makes it worth.
endless_pain is offline   Reply With Quote
Old 02-16-2018, 09:21 AM   #6
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I think used transmissions go for around 400$. You might be able to roll the dice on that one if you don't want to shell out 6k.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 02-16-2018, 12:03 PM   #7
hichamaziz
Drives: subaru brz
switch from motul to redline oil
hichamaziz is offline   Reply With Quote
synchro issue, transmission, transmission grinding
Is a catback install possible with just jacks? jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 02-20-2021 09:45 AM
New Vendor: Jacks Transmissions is on board! JacksTrans Transmission and Driveline 6 09-13-2016 07:32 PM
Harbor Freight Jacks White64Goat Other Vehicles & General Automotive Discussions 28 12-27-2014 07:16 PM
Jacks/stands around central nj? Reflex NY / NJ / CT / PA 9 09-13-2013 11:30 AM
Are my accessory jacks plugged in? dale.m Electronics | Audio | NAV | Infotainment 3 10-09-2012 12:14 AM
