Old 01-31-2018, 08:34 PM   #1
Brz_racer
Drives: Subaru BRZ
Clutch pedal squeaking when clutch is in motion
So I recently had the engine block replaced on my 14 brz. They also replaced the throwout bearing while they were in there. Recently the clutch pedal has started making a squeaking noise when I press it, but only while the pedal is moving. Makes no difference whether the car is on or off. It sounds something similar to walking in wet flip flops. I took it to the dealer who did the work and they told me the pressure plate fingers are the cause of the noise. I suspect the throw out bearing. Has anyone else here experienced a clutch noise like this? And if so what was the cause.
Brz_racer is offline   Reply With Quote
Old 01-31-2018, 09:27 PM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Have somebody listen around the engine bay while you operate the clutch. The first and easiest thing to check is that the push-rod on the slave cylinder is properly greased, it will squeak if dry. If that isn’t it, I would suspect the throw out bearing... but if that is being replaced you might as well replace the whole clutch assembly while the transmission is out.
NCtoBRZ is offline   Reply With Quote
Clutch pedal squeaking, power loss in 6th Lynxis Issues | Warranty | Recalls / TSB 27 02-01-2018 07:26 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
clutch squeaking impossible Engine, Exhaust, Transmission 3 05-11-2016 08:48 AM
Clutch squeaking dallenj Engine, Exhaust, Transmission 14 05-03-2016 12:17 PM
Clutch Squeaking? wise345 Engine, Exhaust, Transmission 6 04-28-2016 02:58 AM
