Old 04-25-2016, 06:48 PM   #1
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Clutch Squeaking?
I only run the OFT stage 2 tune so its not a power thing. I have 25k miles on my car. Problem is when i push the clutch in it squeaks and squeaks again when i release it. It engages and disengages fine so I'm assuming its an issue with the pedal assembly itself, any ideas?
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 04-25-2016, 11:47 PM   #2
humfrz
@wise345 , it could be that the arm (clutch fork) that moves the release (throw out) bearing is dry.
humfrz
Ultramaroon (04-25-2016)
Old 04-26-2016, 02:49 AM   #3
Irace86
Drives: BRZ + Ducati M796
Search. There are many pages on the topic.
Irace86 is offline   Reply With Quote
Old 04-26-2016, 03:09 AM   #4
psybre
psybre's Avatar
search will help, but I'll just say I had the same issue, got really loud and creaky. happened whether car was on or off.
Toyota said the pressure plate and bearing were causing excessive noise from the clutch, and they replaced, under warranty:
SU003-00802 BEARING, RELEASE
SU003-00800 COVER CP-CLUTCH
SU003-02179 RADIAL BALL BEARING
Since they dropped the transmission, I had them replace the clutch and resurface the flywheel, too. Didn't pay for labor since the labor was covered by the warranty work.
psybre is offline   Reply With Quote
Old 04-26-2016, 12:43 PM   #5
wise345
wise345's Avatar
I'm boosting in June and am putting in a new clutch. Think it'll solve my problem?
Old 04-26-2016, 02:01 PM   #6
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I had the squeaking and it was from the clutch fork pivot
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
jcw99 (04-28-2016)
Old 04-28-2016, 02:58 AM   #7
psybre
psybre's Avatar
if nothing else, opening up the transmission and seeing what's actually happening should help. I would try to narrow down the source of the sound - make sure it's not coming from the clutch pedal assembly (especially where it passes through the firewall), and see if you can get a friend to push the clutch in while the hood is up so you can pinpoint the sound. Mine was really, really loud - louder than a squeaky door, and I could feel the creak in the pedal when it was happening.
If it's just the clutch fork, you might be able to lube it up if you've got tiny skinny fingers. There's a DIY here somewhere. I don't have sausages by any means but that is a cramped, tiny hole you have to lube up.
Windows Squeaking Froylavin Issues | Warranty | Recalls / TSB 164 02-24-2018 01:41 PM
Squeaking noise when depressing clutch pizzahead20 CANADA 20 10-29-2016 08:36 AM
Help! Coilovers squeaking Sw33tm1x Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-20-2016 12:05 PM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
Squeaking windows bdanisi Scion FR-S / Toyota 86 GT86 General Forum 29 02-10-2013 10:54 AM
