Drives: 2013 WRB BRZ 6MT
Clutch pedal squeaking, power loss in 6th
So I noticed yesterday that my clutch pedal was squeaking on return stroke and making a bit of a vibration as it squeaked. Sound is more like a creaking noise really. I did some reading and watched some videos and the throw out bearing is likely the culprit. Not a big deal, I'll get it dealt with later this week.
Then I noticed on my way home while cruising along in 6th gear at around 2000rpm that I started to lose speed on a slight incline which hasn't happened before. I gave more and more throttle and the car still refused to accelerate even wide open throttle. Downshift to 5th and it can accelerate again. Back to 6th, still no power so I stay in 5th until I get home. No check engine lights and I ran fault scan anyways, no faults found so not convinced it's an engine problem. Stick car in neutral with clutch out and rev, seems to rev normally. Clutch in and rev, it's similar. Anyone think this might be related to a bad clutch/TOB issue? I'm a little weak in my knowledge/experience of this particular area and don't know how they can affect things like this. I can imagine a slipping clutch could cause this but I understand the revs would go up if that was happening and they did not when I was flooring it in 6th. I also can't really tell if the power is similar in 5th than usual because it's kind of weak anyways. Tried 2nd gear pull and it felt mostly normal but once again, hard to say, I haven't driven hard in months since too much ice and snow here. Looking for opinions. Planning to take it to Subaru tomorrow although I'm now 2 months out of warranty so not sure what they'll do if anything... |
#2 | |
I'll stick my neck out and speculate that the TOB is freezing up. What ya'll think?? humfrz |
#3 | |
not playing cards
I'll go WAY out on a limb with the lack of oomph because I've experienced it in heavy rain. Was there any slush/snow/ice on the that incline?
I have felt in the VSC what I can best describe as an integration function. If enough short periods of wheel slippage are detected within some period of time like 10-30 seconds, it will secretly pull throttle. I'm pretty comfortable with water. When I cross enough little puddles going fast enough to induce teeny bits of hydroplane, VSC gets passive-aggressive. Without any other indication the car slows down no matter how much I mash the gas pedal. It also takes a while for the condition to clear itself. Super annoying. Does that sound plausible in your situation?
#5 | |
I will note that the clutch is still squeaking on engagement but it's not nearly as loud as it was yesterday. I could hear it over the fan at the "2" position yesterday (My premium BRZ has same HVAC controls as an FRS) where I had to have the fan completely off today to hear it. I wonder if there was some funny business with the TOB/Clutch that engaged the mode Ultramaroon referenced yesterday. Car was handling funny for sure at the time too. |
#6 | |
not playing cards
Squeaky clutch pedal while pressing or releasing is almost certainly the dry fork pivot. It'll come and go with the weather. Just have to clean & lube. Resistance while pressing, or hangup while releasing is a symptom of the TOB binding on the quill. That needs to be addressed. It gets pretty ugly from there on.
#7 | |
#8 | |
Oh and it gets quiet for a bit before it blows up.
#10 |
Huge E85 fan!
Drives: 2016 Scion FRS
I can't see how this would be a TOB issue. If it won't accelerate in 6th up a hill, if you don't smell burning clutch, it's not the clutch either. I wouldn't worry about it unless you see a pattern of behavior develop. One time could be a fluke thing- any number of a hundred things.
Do you have Torque Pro? If so, start watching your numbers (AFR, Fuel Trims etc) while you drive. No CEL, o probs with fuel trims, everything looks OK, don't panic. Grease the fork (easy fix for the squeak) but the rest I think was just conditions outside. |
#11 |
Yeah not so concerned about the TOB, there are no other symptoms with the clutch other than the noise that comes and goes.
Power loss happened again last night and I actually think I may have a brake dragging because as I mentioned, the car seems to handle funny when it happens and I was hearing an unfamiliar noise. There's been a lot of freezing rain lately so it's possible one of the calipers has frozen or seized. I'm going to take it to the coin op car wash on the way home tonight and blast the wheels out and hope that clears it up. |
#12 | |
You may wish to jack up the wheels and spin them to see if the brake is dragging ..... ![]() humfrz |
#13 | |
not playing cards
#14 |
Huge E85 fan!
Make sure there's no ice build up under the wheel wells. Feel the wheels when this happens and see if one is a lot hotter than the others- brakes will create a ton of heat when they drag. I forgot about brakes dragging and that you're in a very cold place.
| clutch squeaking | impossible | Engine, Exhaust, Transmission | 3 | 05-11-2016 08:48 AM |
| Clutch squeaking | dallenj | Engine, Exhaust, Transmission | 14 | 05-03-2016 12:17 PM |
| Clutch Squeaking? | wise345 | Engine, Exhaust, Transmission | 6 | 04-28-2016 02:58 AM |
| BRZ gas pedal popping/squeaking noise | chenshuo | Issues | Warranty | Recalls / TSB | 8 | 05-10-2013 09:52 AM |
| CEL, Loss of Traction Light, Loss of Power | pituala | Issues | Warranty | Recalls / TSB | 19 | 09-05-2012 11:23 AM |
