Old 04-10-2017, 09:51 PM   #1
ducky369
Drives: 2014 Frs
No brake light, dash showing abs and traction
As the tittle saids, I'm getting no brake light when I step on the brake, I can't take it out of P because it's not sensing the brake. Fuse 4,6,14,15 looks good.
Anyone know what's the problem?
ducky369 is offline   Reply With Quote
Old 04-10-2017, 10:38 PM   #2
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Know anybody with a code reader?
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 04-10-2017, 11:38 PM   #3
humfrz
You might check fuses 13,16 and 26.
humfrz
Old 04-11-2017, 04:43 AM   #4
ducky369
Drives: 2014 Frs
humfrz
all fuse looks good, but the brake lights just don't light up
Old 04-11-2017, 05:40 AM   #5
steve99
Check the brake pedal switch.
If the brake pedal switch is stuffed, the you will get no brake lights, wont come out of park or start as ecu wont detect brakecpedal pressed and may upset vsc traction system as it wont know brake pressed
Could be brake switch at pedal or the wiring\plug
Old 04-11-2017, 12:51 PM   #6
ducky369
Drives: 2014 Frs
before I went to bed, I took off the brake light switch.. is the button suppose to be like non clickable button? I expected it to have a click. Going to the shop now to use a continuity tester on the switch and read some obd2
Old 04-11-2017, 12:53 PM   #7
STV3
Señor Member
STV3's Avatar
A friend of mine had this same exact issue and it was the brake switch that needed to be replaced.
STV3 is offline   Reply With Quote
Old 04-11-2017, 02:09 PM   #8
ducky369
Drives: 2014 Frs
just checked, no continuity coming from switch. No difference in meter when pressed or not
Also it's loose like crazy, is there a spring feed back or something? Like it's suppose to feel like a mechanical keyboard ?
Old 04-11-2017, 03:16 PM   #9
ducky369
Drives: 2014 Frs
Update: turns out is the brake light switch under the peddle.. we cracked it open and it was burnt.. we pushed out the contacts now its good.. temporary fix so I don't get a ticket. called wholesale parts through shop and it will be here tomorrow. There's only one in california from Toyota other than that it will have to be shipped from Portland. Subaru takes 3-4 days.
The Following User Says Thank You to ducky369 For This Useful Post:
steve99 (04-11-2017)
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
Brake light on dash comes on when stopping sjcurtis Issues | Warranty | Recalls / TSB 17 03-15-2017 09:29 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
ABS, Traction control and brake light??? JMoore412 Issues | Warranty | Recalls / TSB 18 08-20-2014 05:09 PM
Traction control, abs and brake light all on? JMoore412 Issues | Warranty | Recalls / TSB 0 08-12-2014 07:27 PM
