Old 01-22-2018, 02:40 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Help! Differential bushing bolts mis-aligned
Installing the whiteline differential mount in cradle bushings. Added the bottom vertical bushings and as I go to retighten the drivers bolt will not thread smoothly. Once I tighten it to max torque it still has about a 1/4 gap on the bottom washer. I don't know what to do..I've tried wiggling and repositioning the diff as much as I can but it doesn't solve anything. Is it possible the female threads are bent?
Thanks
Spacemane969 is offline   Reply With Quote
Old 01-22-2018, 02:49 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
Sounds like you have at this point crossthreaded it. Best to remove the bolt and bushings and run a tap through it nice and straight and start over.
jasonojordan is offline   Reply With Quote
The Following 2 Users Say Thank You to jasonojordan For This Useful Post:
Spacemane969 (01-22-2018), Tcoat (01-22-2018)
Old 01-22-2018, 03:11 PM   #3
strat61caster
strat61caster's Avatar
http://www.autoserviceprofessional.c...threads?Page=2
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
solidONE (01-22-2018), Spacemane969 (01-22-2018), Tcoat (01-22-2018)
Old 01-22-2018, 04:08 PM   #4
Spacemane969
Jesus. How bad could this be if I can't get the thread going? This might be a rookie mistake but I was unable to get all four corners on jack stands safely so I've been working with just the rear raised. Does that matter?
Old 01-22-2018, 04:46 PM   #5
strat61caster
Wrench on things long enough and you will wreck a thread or two over the years. You're not the only one, especially on this subframe. Having only the rear raised may have hurt you in getting everything lined up, but it's possible to get it right with the car like that as well as it's possible to get it wrong even with everything lifted evenly.
ineedyourdiddly
Old 01-22-2018, 04:52 PM   #6
Spacemane969
I'm thinking it's mostly the weight of everything that is making the alignment impossible. I have a very cracked uneven driveway and the weight of the whole car could be leaning to the left or right side more than the other.
Thanks for your reply
Rear Differential Bushing Bolt Torque Specs? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-06-2017 10:36 PM
FS: Whiteline Differential Bushing Inserts skylinekin Transmission and Driveline 3 05-31-2017 11:21 AM
Whiteline Rear Differential mount bushing Fail NoGoodNames Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-22-2016 01:08 PM
Differential mounting bolts part # help slicktop Engine, Exhaust, Transmission 0 04-18-2016 09:59 AM
FS: Whiteline Differential Mount Cradle Insert Bushing byun Transmission and Driveline 2 12-28-2015 05:31 PM
