Old 04-12-2016, 12:17 PM   #1
NoGoodNames
Drives: Toyota GT86
Whiteline Rear Differential mount bushing Fail
Hello
These are pictures of the rear differential mount bushing of my car. They are the KDT924 Rear Differential - mount in cradle bushing.
Second time on the track with them installed. On the track I had a very light accident to the rear right side of the car. when the car slide and hit the barrier. Don't know if that was the reason, because that was the only time i noticed the damage when i was under the car looking if there was any damage to the car. So far that was the only thing i noticed.
The hit the car took was very light. I will be very surprised if that caused the bush to come out like that.
My question is did this happen to anyone before? Is the bush the weakest point, and the first to get damaged in these kind of accident?
NoGoodNames is offline   Reply With Quote
Old 04-13-2016, 08:49 AM   #2
NoGoodNames
Drives: Toyota GT86
The only explanation I can come up with right now is.at the track the heat from the diff beaked the glue,epoxy, or what ever material that's bounding them together. And the hit the car took was enough to move it from its place.
Old 04-14-2016, 01:34 AM   #3
Falcon
Drives: WRB BRZ
Sounds plausible.
What are you doing next?
Reglueing? New Ones?
Falcon is offline   Reply With Quote
Old 04-14-2016, 01:57 AM   #4
NoGoodNames
Drives: Toyota GT86
I tried reglueing but the black rubber is damaged and it won't sit properly.
So I ordered new ones.
Old 04-19-2016, 05:02 AM   #5
Falcon
Drives: WRB BRZ
Have you reported the Issue to Whiteline?
I think it will be helpful for them to get the feedback.
The Following 2 Users Say Thank You to Falcon For This Useful Post:
Irace86 (04-19-2016), Speck (04-19-2016)
Old 04-19-2016, 05:17 AM   #6
Speck
Drives: '13 FR-S
This
Speck is offline   Reply With Quote
Old 04-22-2016, 11:52 AM   #7
NoGoodNames
Drives: Toyota GT86
Yes i tried to contact them before i post here, But there was a problem with there email system.
Will try again.
Old 04-22-2016, 01:08 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
dang, haven't seen this before.
Maybe time for one of the hardcore aluminum diff mounts lol-no glue to fail
Rear Differential Bushing Bolt Torque Specs? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-06-2017 10:36 PM
FS: Whiteline Differential Mount Cradle Insert Bushing byun Transmission and Driveline 2 12-28-2015 05:31 PM
FS: Whiteline positive shift (trans mount) and subframe bushing kit twincamRob Transmission and Driveline 9 02-17-2014 01:17 PM
Whiteline Rear Crossmember-Mount Insert Bushing: Great pricing b2autodesigns Brakes, Suspension, Chassis 1 02-18-2013 11:41 AM
