Drives: 2016 FRS
Anyone know the noise?
Anyone know what is causing this noise? Car is not on, just let in ignition. It does not stop and is extremely load as in you would almost have to yell at someone if there beside you. Took video of it below.
2016 13,000KM Last edited by Newtothegrounds; 01-21-2018 at 05:15 PM. |
#2 | |
![]() So, the engine is NOT running ..?? The ignition switch is ON ..?? Does the sound stop when the ignition switch is OFF ...?? Come back ...... ![]() humfrz |
Drives: 2016 FRS
Correct NOT running, key is just in ignition, happens on full accessory. Should have added its coming from throttle body area (intake manifold).
Video does not justify how loud it is, climate controls turned off so not a blower fan for heating or cooling and not the rad fan. |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
If it were me, I'd use a stethoscope or hose/rod to determine where the noise is coming from then start pulling fuses or dis-connecting connectors to see what makes it stop.
| The Following User Says Thank You to BirdTRD For This Useful Post: | humfrz (01-21-2018) |
Bubba suspects the horn is sick and stuck - he says to pull the fuse or rap on the horn with a BF screwdriver .......
![]() Bubba ain't usually right ...... but, he tries ...... ![]() humfrz for Bubba |
| The Following User Says Thank You to humfrz For This Useful Post: | BirdTRD (01-21-2018) |
Drives: 2016 Subaru BRZ
Why not just drop it off at the dealer? I assume your car is still under warranty at that mileage and MY.
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
Drives: 2016 FRS
If possible I try not to go to the dealership for anything I've had issues in the past with other vehicals that had to get legal. It did go in my favour but I hate going to the slime bag place.
Drives: JDL Turbo BRZ
Mine has done this ever since I can remember, and from what I diagnosed, it's related to the throttle body stepper motor. I believe you are hearing a particular resonant frequency emitting from the internal electromagnets that are trying to maintain the stepper's position. The reason you can hear it just in accessory is because the engine will mask that sound while running.
I really don't think it's anything to worry about. |
| The Following 2 Users Say Thank You to Jesse36m3 For This Useful Post: | humfrz (01-21-2018), Ultramaroon (01-21-2018) |
#10 | |
I hope you get it resolved either way though. Best of luck. |
#11 |
not playing cards
It's just the throttle servo holding idle position. Have someone slowly step on the throttle while you're listening. It's fine.
#12 |
Drives: 2016 FRS
K thanks for the info guys. I'll try the throttle it should change even if it's a tiny bit like your saying.
#13 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
That is quite loud. Can you hear it like that in the cabin? Being so close to the firewall I have to figure it goes through pretty clearly.
-O/D
2016 FR-S, Hot Lava |
#14 | |
![]() Confirmed by @Ultramaroon ...... so, it must be right ...... Yep, I checked mine and it does it too ....... but not nearly THAT loud ...... ![]() humfrz |
| Road noise? Tread Noise? | zERoTu | Issues | Warranty | Recalls / TSB | 21 | 10-07-2020 10:21 PM |
| Help with a noise please. | Crosscharge | Issues | Warranty | Recalls / TSB | 5 | 07-18-2014 02:47 PM |
| Is it THAT noise? | Taro | Issues | Warranty | Recalls / TSB | 5 | 09-23-2013 09:21 AM |
| Fan noise? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-30-2012 05:22 PM |
