Old 01-21-2018, 12:42 PM   #1
brkn86
Drives: 2002 Acura Rsx & 2013 Scion FRS
OFT Backfire Effects
A few months ago I purchased an Open Flash Tablet after a while i came across this "Backfire/Pop" tune and tried it out and was pretty fun hearing the exhaust pop and crackle and seeing people heads turn around lol. I wanted to know who has been on this tune for a long time? Such an more than a year, if you have ran into any issues or problems? I just want to know if im going to run into any negative effects. P.s im full catless so no worries about my cat going out or my muffler packing.
Thank you!
brkn86 is offline   Reply With Quote
Old 01-21-2018, 09:17 PM   #2
Northern_18
Drives: Silver 2016 Scion FR-S
If you take a look at recent posts on this thread there has been some of those questions that have been answered: http://www.ft86club.com/forums/showthread.php?t=61069
From the looks of it there seems to be a consensus about it not causing any damage. Some people have run the tune for a long time without noticing any problems arising. The only thing that gets brought up is the muffler packing takes a beating and may damage the muffler and make the exhaust louder but you seem to be aware of that risk.
Northern_18 is offline   Reply With Quote
The Following User Says Thank You to Northern_18 For This Useful Post:
brkn86 (01-22-2018)
Old 01-22-2018, 08:13 PM   #3
brkn86
I was just curious to hear about those who have been running it and hearing any updates since than. Thanks for the link
Old 01-22-2018, 10:27 PM   #4
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
I could see that getting annoying after a while
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
Old 01-23-2018, 09:32 PM   #5
Northern_18
So apparently it is very easy to have it only pop on demand (when feathering the throttle when decelerating). Probably gets old fast but might try it someday to see for myself.
Ghost of Akina (01-23-2018)
Old 01-24-2018, 05:44 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I first did this mod last Summer sometime. Not much to go on, but so far so good. If you have a low tolerance for noise or are embarrassed easily it's not the mod for you.
Others have the timing retarded a lot more than me and have a much louder set up (I know there's a couple 86's in my town who do because I hear it!) I have mine set up so that the first column of Table B has much less timing advance (IIRC 5 degrees advance), I am not running retarded timing- the standard is around 15 degrees of retard. That shit is loud with pops, shotgun shots, cherry bombs and automatic gun fire. Mine burbles and pops a lot, not many gun shots.
Old 01-24-2018, 08:34 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
So is there a performance reason for this, or is it to just be a noisy jackwagon?
The Following User Says Thank You to Summerwolf For This Useful Post:
Tcoat (01-24-2018)
Old 01-24-2018, 08:49 AM   #8
Just noise. And I know I will get hate mail and "but mine has been fine" replies but there is no way in hell that backfiring all the time is OK for an engine. None. Zero. Zip. Zilch.
soundman98 (03-24-2019), Submarinesonce (01-24-2018)
Old 01-24-2018, 09:14 AM   #9
bababooey
Drives: BRZ SWP Limited -6MT
i dont understand how the more timing retard would make a difference. once the fuel mixture exists the chamber it shouldnt matter when the ignition fires, just as long as its after the chamber is clear.
Old 01-24-2018, 09:17 AM   #10
Teseo
Drives: frs
If it clog the catalytic, would clog the valves
Old 01-24-2018, 12:10 PM   #11
slowest86
Drives: slow frs
So what you're saying is this will melt the valves? I don't know about that.
slowest86 is offline   Reply With Quote
Old 01-24-2018, 12:48 PM   #12
Tokay444
Please, SOMEONE tune for a backfire.
Then try a warranty claim for the blown up manifold and all the pieces inside the combustion chamber.
Old 01-24-2018, 01:17 PM   #13
Teseo
Drives: frs
No melt, just heavy carbon build up on valves. That prevent the valve to close completly, at least in theory. Backfire was used on world rally cars to keep the turbocharger spoiling when driver release throttle pedal in turns, in straights the turbo is on the "sweet" spot and accelerate more quickly.
Old 01-24-2018, 01:21 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I get lots of pops and backfires on the normal OTS 91 octane tune. No special tweaks required.
Catless FP and Tanabe single exit FTW. (stock header)
Originally Posted by humfrz
I'm old and lazy
Backfire on BRZ? BRZSteve Issues | Warranty | Recalls / TSB 10 11-28-2015 05:55 PM
Backfire + Loss of power RavioliG Issues | Warranty | Recalls / TSB 2 11-16-2014 09:56 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
Backfire Intake SherbFrs Issues | Warranty | Recalls / TSB 45 06-26-2013 08:38 PM
Backfire when shifting canu_50 Issues | Warranty | Recalls / TSB 39 09-27-2012 01:55 AM
