Drives: Toyota GT86
backfire at cold start
hello all together!
Have you also already experienced backfire at a cold start when you step on the gas while pushing the sart button? I´m asking cause i question myself if this is a normal reaction or if i should better go to the dealer Hope for some experiences! |
Drives: Sliver FRS done the way I like it
No its not normal , I have had the same issue even while driving , take it in have them look at it the are replacing my ecu and check DI seals ...
Dirt Trackin'
Drives: '13 Raven FR-S MT
I don't think you should need to step on the gas while you are trying to start the car...
#4 | |
Drives: '13 FR-S
You don't have carbs.
Don Ivey
'13 FR-S (Hot Lava) |
Don't care
Drives: 2013 Whiteout FRS
#6 | |
![]() humfrz PS - no, my car doesn't backfire at startup.... it just peacefully goes through its little warm up dance. |
Drives: Toyota GT86
it just happens if i step on the gas
of course i know i don´t need to hit the pedal while starting but i was wondering if i was the only one with that occuring |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
This happens to me in the mornings. Only when my car is started cold (from being sitting outside for 12+ hours).
1.5k-2k RPM idle with intermittent popping for 30 seconds. Then it dips to 1k RPM with no popping. Drive away with no popping. |
#10 |
Drives: Toyota GT86
oh okay then it seems as it´s normal
![]() always just happens to me when the engine´s cold and i give a little burst. |
#11 |
is better than you
Drives: 2013 raven FRS
so your intake sounds like it's going to blow up?
#12 |
Drives: Toyota GT86
i don´t exactly know where it comes from but would be interesting if someone knows
only thing i hear it the really loud popping when pushing the gas at cold start if i don´t do that everything´s normal no gas no popping |
#13 |
Scrape Master
Drives: Goal: Oldest FRS State Side
It happens to me sometimes but i have a borla cat delete plus muffler delete. On rare occasions my car will take some cranks to get going, once it starts and i hit the throttle my car will backfire alot but then stops.
#14 |
is better than you
backfire is when your intake is blowing up lol. When its comming from the exhaust it's called after fire
| Exhaust rattle on cold start? | Laurie | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-04-2020 07:15 PM |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold start up popping noise | Weeber | Issues | Warranty | Recalls / TSB | 51 | 09-23-2016 12:54 PM |
| Loud misfires upon cold start | connorlug | Issues | Warranty | Recalls / TSB | 42 | 03-31-2016 04:43 PM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
