Old 11-16-2014, 09:20 PM   #1
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Backfire + Loss of power
Was at a local track this weekend and as I was laying down the power around one particular corner every time the car would fuel cut(?) at high rpm, and backfire multiple times.
I have a video of it filmed from my friends car behind me. (I'm the red BRZ).
It backfires three times in this video, two quick small ones as I'm approaching the corner (WOT + 3rd gear), and then one big one as I'm powering out of the corner (WOT + 3rd gear).
As soon as I heard the second pop and felt the loss of power, I pulled aside and let my friend pass.
There was no check engine lights after the backfires, and the car was fine everywhere on the track except the same corner for all laps past this.
At this point in the day I had half a tank of gas and this all happens right after a big sweeper.
Would this be enough to fuel starve it?
Could it be a direct injector seal issue?
A while ago, I had a check engine light for P0352 "Ignition Coil "B" Primary/Secondary Circuit" but the light mysteriously went away after a week. Could it have something to do with that?
Engine mods are: OFT E85 tune, Muffler delete, Drop in filter.
Can anyone shed light on what the problem might be?
RavioliG is offline   Reply With Quote
Old 11-16-2014, 09:22 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
replace coil pack.
http://www.ft86club.com/forums/showthread.php?t=52688
Old 11-16-2014, 09:56 PM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The consistency of it happening in that turn, especially a long sustained turn, is indicative of fuel starvation. I remember reading a thread once where "half tank is the new empty" or something of that nature. I would think it's a coil pack misfire but there's other straight sections of the course where you don't seem to get that problem when you'd presumably be heavier on the throttle.
zkv476 is offline   Reply With Quote
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
Erractic loss of power at low RPM Bg8780 Issues | Warranty | Recalls / TSB 8 05-01-2013 03:13 PM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 06:24 PM
