Old 01-18-2018, 07:08 PM   #1
BOND007_LTK
Drives: 2013 brz
Lower Heat Isn't Hot
Anyone find that leg/lower heat/heater isn't hot?
This is after full warmup and compared to full blast of hot air for upper air alone, the lower heat alone is about 23 degrees celcius at most (room temperature) and at least half as weak in blowing the air out.
BOND007_LTK is offline   Reply With Quote
Old 01-18-2018, 07:28 PM   #2
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Close the vents you're not using, if any. I rarely have passengers (their loss), so I close the right vent in the center and the passenger side vent by the door, and that increases the airflow to whatever else is still open.
I don't think the floor heating is bad when the car is at optimum running temp. This car actually has some of the best heat I've had in a car besides my old Corolla. Feet get toasty pretty quick from my experience. Sometimes I switch to it just to spread the heat out a bit, rather than turn the temp down, so my knuckles and face don't get cooked by the upper vents when I have the heat set to Hell.
Are you using the fresh air setting or the recirculation? It does make a bit of a difference, and if your cabin air filter is clogged up that will affect the airflow in the recirculation setting.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 01-18-2018, 07:58 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Cabin air filter affects both fresh and recirc. You're good as long as you can see light through it.
Cole (01-19-2018), Leonardo (01-18-2018)
Old 01-18-2018, 08:23 PM   #4
Overdrive
Sittin' Sideways
Overdrive's Avatar
That so? Suppose I stand corrected, then.
-O/D
2016 FR-S, Hot Lava
The Following User Says Thank You to Overdrive For This Useful Post:
Ultramaroon (01-18-2018)
Old 01-18-2018, 09:21 PM   #5
humfrz
Maybe the lower vent isn't being opened up all the way......
Have you been messen around under the dash lately ..??
humfrz
Old 01-18-2018, 09:25 PM   #6
humfrz
I can see light through chicken wire ......
Why do chickens lay eggs with different colored shells, when they are penned and all are fed the same chicken feed ......
humfrz
Old 01-18-2018, 10:29 PM   #7
Ultramaroon
not playing cards
No worries, brotha.
Old 01-18-2018, 10:41 PM   #8
Ultramaroon
not playing cards
[ame="https://www.youtube.com/watch?v=BA3lD8jxR2A"]for humfrz - YouTube[/ame]
Why does chili taste better the next day?
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
arkanist (01-19-2018), Clipdat (01-19-2018), Cole (01-19-2018), humfrz (01-18-2018)
Old 01-18-2018, 11:40 PM   #9
humfrz
Chili taste better the next day because the next day you hadn't gotten tired of messen with it and tasting it all day long.
Plus, time has allowed the flavors to come together.
Now, what about the egg shell thing ....... chicken farmer ??.........
humfrz
Ultramaroon (01-19-2018)
Old 01-19-2018, 12:24 AM   #10
Ultramaroon
not playing cards
Like a dog on a bone, ain't ya.
Hell, I dunno. They both scramble the same. That's all that really matters.
humfrz (01-19-2018)
Old 01-19-2018, 09:54 AM   #11
Icecreamtruk
Drives: Track preped NA FRS
Color of eggshells is determined by genetics, much like the color of human hair. Some colors are dominant traits while others are recesifs, so the probably isnt a 50/50 split. What was this thread about again?
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
Cole (02-05-2018), Ultramaroon (01-19-2018)
Old 01-19-2018, 11:07 AM   #12
Overdrive
Sittin' Sideways
Overdrive's Avatar
Floor heat? Eggs? Floor heating your eggs?
-O/D
2016 FR-S, Hot Lava
The Following 3 Users Say Thank You to Overdrive For This Useful Post:
Cole (02-05-2018), Icecreamtruk (01-19-2018), Ultramaroon (01-19-2018)
Old 01-19-2018, 11:13 AM   #13
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Personally, I think this car has one of the best heating systems of any car I've had. There's heat at the vents within a minute or two of driving, and it gets hot enough to bake a potato.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 3 Users Say Thank You to venturaII For This Useful Post:
Cole (02-05-2018), Overdrive (01-19-2018), Ultramaroon (01-19-2018)
Old 01-19-2018, 01:17 PM   #14
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Yes I noticed the same thing and found it strange.
The floor heat is noticably colder than the top vents, and when the aiflow setting is low, there is not a lot of air coming out the floor.
For the temperature maybe it's intentional design. In cold climate most people are wearing boots or insulated shoes during winter, so if the air at your feet was the same temperature than the one blowing at your hands/face, then your feet would be really hot with the boots and all.
But it could be a bit warmer.
PS: I have automatic climate control, but use it mostly in manual mode.
nico_rsx is offline   Reply With Quote
Combating the heat toekneehair Forced Induction 823 12-23-2021 08:06 PM
FS: OEM Heat Shield MicheleAbbate Engine, Exhaust, Bolt-Ons 11 10-24-2018 06:24 PM
Heat cycled. forwallblakmail Tracking / Autocross / HPDE / Drifting 23 06-25-2014 10:45 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
