Old 01-03-2018, 10:19 PM   #1
jeschris45
Drives: Yellow FR-S Rs 1.0
Location of Automatic Transmission drain plug
Can someone help me find where the drain plug would be based on this picture? I can see the overflow and fill plug.
jeschris45 is offline   Reply With Quote
Old 01-04-2018, 01:49 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
......uh.... you trolling bro?
Read any manuals lately bro?
Old 01-04-2018, 02:14 AM   #3
humfrz
Well, hello jeschris45, and welcome to our forum .......
So, you are fixing on changing the AT fluid in the AT on your car.
Curious, do you really have at least 60,000 miles of your car .. ??
I would take a wild guess that the drain plug is the one on the bottom of the lower picture.
It's my understanding that changing the fluid on this AT is a bit more involved than simply draining out the old fluid and filling with new fluid.
Are you aware of this .. ??
If you would like to double check your understanding of the process, I'm sure there is some instructions which can be found on this forum.
Have fun!
humfrz
Old 01-04-2018, 11:59 AM   #4
jeschris45
Thank you humfrz. Yes I read the instructions on how to do the change. There was a forum that had the pictures with instructions on how to perform an ATF change. I was going to do it this weekend. I was just trying to ask around, because according to the picture I saw from the forum I could only see the fill and overflow plug(bottom of the pan). I looked at the manual this morning on assembling the oil pan for the automatic transmission, and I think I have figured out the location. It looks like the drain plug and overflow plug both are at the bottom of the pan somewhat next to each other, just like the mx-5 autos.
Why isn't there a 2nd drain plug on the bottom of AT oil pan? FT86.ca Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-04-2017 08:40 PM
Drain plug leaking...what to do... OUGrad05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-28-2016 02:01 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 01:07 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 06:20 PM
