Drives: 2015 FRS Whiteout
Wide Body Wheels
What would be the size for wheels if I were to go to put on a widebody kit like the VR-S or a rocket bunny kit
#2 | |
Drives: Boosted
Depends on the version. V1 you can go with a 9.5 in the front with an effective offset of 0-20 whether you get that through spacers or have wheels specifically made in that offset (3p / replicas) The rear you generally want an anywhere between a 9.5-11.5. The rears I'd run an 11 with an offset of 0-10. You can run a 9.5 as well but you'd need to run a much lesser offset like -35-45. Theres a thread about this as well. http://www.ft86club.com/forums/showthread.php?t=20429 I'm personally running a 9.5 in the front with an offset of -8 and an 11 in the rear with an offset of -7. I'd like to keep my offsets not too low due to being mounted further away from the hub which causes additional stress for the bearings. I know some people run stronger extended studs when they go anything aftermarket with offsets this low due to the additional stress. |
Drives: 2014 GT86
Stronger wheel mount studs won't do a thing to change scrub radius and thus extra load on bearings. Just wheel centerline position vs that of stock. If one targets flushness with wide body kit, that extra load & heavier steering will be there no matter which studs are used and no mattter if wished for flushness offset is reached with specific sized wheels or spacers. Funilly, issues of very big scrub radius might be less with wider wheels/tires though, as to get same flushness, wheel center line don't need to be that much off to side as if with narrower wheels.
#4 | |
Drives: Boosted
Drives: 2014 GT86
incutebus: stock studs should be strong enough even then. About the only way one may need those extended studs, is not in case of large offset in general, but if that offset is reached using slip-on spacers, to get enough threads for lugnuts even if some stud length is "spent" on spacer portion. It's not the studs, that keep wheel in place, studs are actually rather weak if full weight loaded from side, it's the friction between wheel and hub. You torque lugnuts with same force even on wheels with more offset. Now if there is not sufficient friction between hub and wheel, such as untorqued lugnuts, you've got problem, if wheel hangs just on studs, that are not meant for that. But then again it would be problem also with stock wheels at stock offset.
#6 | |
Drives: Boosted
| Wide body wheels | nelsonzep | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 06-29-2016 02:55 PM |
| WTB: Wide body kit | Heru Farukon | Want-To-Buy Requests | 5 | 02-05-2016 04:38 AM |
| Lightweight concave wheels for wide body | WallsAndFoundations | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 07-18-2015 06:51 PM |
| Enjuku Racing's - Origin Lab Wide Body FR-S - What wheels would you choose | Enjuku Racing | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 04-24-2013 01:39 AM |
| Wide Body Question; Wheels. | joergasm | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 02-25-2013 11:48 PM |
