Old 11-22-2017, 12:39 PM   #1
Lonewolf
Lonewolf's Avatar
Drives: Moped
*Anyone tried 215/50 tires on oe wheels? Any rubbing?
I tried searching but didn't have much luck, so I am hoping to get some help from some members about the entitled topic.
Just curious if anyone has tried fitting 215/50 series tires on their stock 17 inch wheels (with stock suspension), and if so, is there any rubbing? I would assume that going from a 45 series to a 50 series should fit within the fender well without much issue, but I would love to hear real-world feedback about sidewall flex, steering response, rubbing issues, and everything else of consequence.
Thank you in advance for your time.
Old 11-22-2017, 12:43 PM   #2
imnotsureaboutbrz
Drives: between cars...
215/50's are my winter set up absolutely no rubbing, my summer setup is a 245/40 so the winter set-up is a much nicer ride. but a cant really speak to steering response because I don't (can't) push the car... snow n all...
imnotsureaboutbrz is offline   Reply With Quote
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
Lonewolf (11-22-2017)
Old 11-22-2017, 01:00 PM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
Have you taken the steering wheel lock to lock (full turn to each side) with your winter setup?
Old 11-22-2017, 01:18 PM   #4
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I'm currently on 225/50/17's with slight rubbing in dips and fronts rub at full lock. widebody fenders so don't know how helpful that'll be to you..
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Old 11-22-2017, 01:45 PM   #5
Lonewolf
Lonewolf's Avatar
Drives: Moped
Are you on the stock suspension set-up? Is the rubbing on the sidewall or the top of the tire?
Old 11-22-2017, 02:32 PM   #6
VIP BRZ
VIP BRZ's Avatar
Cars lowered on coils, in the rears tires rub on the top but not on the apex of the wheel well. towards the rear bumper. You man not have this issue, your stock wheel tucks all the way under the fender.
The issue i think you will have is in the front.. i have rubbing at full lock on the inside of the sidewall.
Old 12-16-2017, 10:55 AM   #7
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump, any other experiences?
Widest wheels without rubbing on stock springs with eibach springs ? H214M Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-09-2017 11:41 AM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 09:42 PM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 02:49 PM
