| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Moped
*Anyone tried 215/50 tires on oe wheels? Any rubbing?
I tried searching but didn't have much luck, so I am hoping to get some help from some members about the entitled topic.
Just curious if anyone has tried fitting 215/50 series tires on their stock 17 inch wheels (with stock suspension), and if so, is there any rubbing? I would assume that going from a 45 series to a 50 series should fit within the fender well without much issue, but I would love to hear real-world feedback about sidewall flex, steering response, rubbing issues, and everything else of consequence. Thank you in advance for your time. Last edited by Lonewolf; 11-22-2017 at 12:59 PM. |
#2 |
Drives: between cars...
215/50's are my winter set up absolutely no rubbing, my summer setup is a 245/40 so the winter set-up is a much nicer ride. but a cant really speak to steering response because I don't (can't) push the car... snow n all...
| The Following User Says Thank You to imnotsureaboutbrz For This Useful Post: | Lonewolf (11-22-2017) |
#3 |
Drives: Moped
Have you taken the steering wheel lock to lock (full turn to each side) with your winter setup?
#4 |
Drives: 2014 Subaru BRZ
I'm currently on 225/50/17's with slight rubbing in dips and fronts rub at full lock. widebody fenders so don't know how helpful that'll be to you..
| The Following User Says Thank You to VIP BRZ For This Useful Post: | Lonewolf (11-22-2017) |
#5 |
Drives: Moped
#6 | |
The issue i think you will have is in the front.. i have rubbing at full lock on the inside of the sidewall. |
#7 |
Drives: Moped
Bump, any other experiences?
| Widest wheels without rubbing on stock springs with eibach springs ? | H214M | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-09-2017 11:41 AM |
| Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? | Eazy-V | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 11-02-2014 09:42 PM |
| Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires | themajesticone | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-04-2014 02:49 PM |
