Old 08-28-2017, 08:58 PM   #1
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Weird AT Transmission shifts
So my AT runs perfect, no issues shifts fast, car is really great. Only issue is if I make a hard left with acceleration the tranny does not shift immediately and will go to 4000 before shifting. Does not do this on hard rights. Not really a problem but its noticeable. Any of the AT guys experience this?
Ernest72 is offline   Reply With Quote
Old 08-28-2017, 09:54 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
so if I'm understanding the concern correctly, while in auto mode when you take a hard left your transmissions goes up a gear and drops your revs to 4000 but when you take a right it stays in a lower gear with the revs up? do you have sport mode on? if so, it shouldn't go up a gear unless you aren't really on the throttle.
HKz is offline   Reply With Quote
Old 08-28-2017, 10:06 PM   #3
phrosty
have never experienced this.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 08-28-2017, 10:58 PM   #4
NOI
NOI's Avatar
Drives: 2 Subarus and a 2013 FRS
nope.
NOI is offline   Reply With Quote
Old 08-29-2017, 12:32 PM   #5
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
As odd of a thing as this is I can actually recall having this happen on my car. Reason being that there is a left turn right before I get home at a light and if im just barely on the pedal it shifts normally for the most part. Now if I give it a little more throttle taking the turn it does seem to rev up higher and hold it before shifting. Reason is I can remember noticing it was because I was thinking why hasn't it shifted up yet.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 08-29-2017, 03:13 PM   #6
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
I also get a certain odd "feeling" when powering into a left turn. I just realized I may get some strange responses from certain people on this forum about this post.....
But seriously, there is a certain "feeling" that I get from the car every once in a while - it's hard to replicate - could be the transmission - never thought of that.
winstonscifi is offline   Reply With Quote
Old 08-29-2017, 03:39 PM   #7
Actually @Earnst72 this may not be an issue but a design feature.
As I recall, the AT was designed to hold the current gear in aggressive curves to avoid a mid-shift that could cause issues with traction. This emulates how on a manual transmission you would not shift gears in the middle of a hard turn. There was discussion of this early on in 2012 when released, but I didn't search.
I have experienced this myself (left or right) if I'm really pressing the throttle accelerating through a turn when in full auto.
winstonscifi (08-29-2017)
Old 08-31-2017, 09:20 AM   #8
rjgough95
rjgough95's Avatar
This is what I always assumed and decided not to worry about it because it seemed to make the most sense.
The Following User Says Thank You to rjgough95 For This Useful Post:
Dadhawk (08-31-2017)
Old 08-31-2017, 06:37 PM   #9
Ernest72
Thanks for the responses. The explanation makes sense so I will not worry about it. Just weird it seems to do it more on left turns than right. No big deal. Ill just press the accelerator down a little bit more.
2015 scion frs rough shifts in automatic transmission Abe1120 Engine, Exhaust, Transmission 16 10-10-2016 04:05 AM
Heel-and-toe down shifts KNS BRZ First-Gen (2012+) — General Topics 39 04-21-2015 08:44 PM
0-60... at below 3-4k rpm shifts iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 29 08-08-2013 09:16 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 01:24 AM
you can see how fasts the shifts are in this vid! its quick!!! carbonBLUE Engine, Exhaust, Transmission 24 04-03-2012 08:25 PM
