Old 10-31-2014, 02:22 PM   #1
KNS
Drives: BMW and Porsche at the moment
Heel-and-toe down shifts
New poster here - seriously considering a BRZ next year. I did a search and really couldn't find an answer... Unless I searched the wrong key words.
I've read that when you apply the brake and the throttle at the same time, the car will cut the throttle as a safety feature. I suppose this is a result of runaway Toyotas and owners not being able to stop the car - which is a whole 'nother subject.
My question: If you are trying to downshift and want to blip the throttle with heel-and-toe technique, does the above feature prohibit this?
I've driven manuals only my whole life and my current car is very easy to heel-and-toe on down shifts.
Thanks. Great forum you guys got here.
KNS is offline   Reply With Quote
Old 10-31-2014, 02:23 PM   #2
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
BRZ is easy to heel and toe downshift. If somebody tells you otherwise, they don't know how to heel and toe downshift.
krayzie is offline   Reply With Quote
The Following 6 Users Say Thank You to krayzie For This Useful Post:
fika84 (04-21-2015), hmong337 (04-21-2015), richardM (04-27-2015), s0sl0w (11-04-2014), SkAsphalt (11-03-2014), Ultramaroon (11-04-2014)
Old 10-31-2014, 02:28 PM   #3
KNS
Thanks for the reply, nice to hear that it's an easy car to heel and toe. But, I take it the throttle does not interrupt while pressing the brake and throttle at the same time? It says so in the brochure I'm just not sure to what extent.
Should have checked it on my test drive.
Old 10-31-2014, 02:35 PM   #4
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
ive never had a problem with the brake shutting off the throttle during heel-toe. mines a 13'.
Flat Black VW is offline   Reply With Quote
Old 10-31-2014, 02:37 PM   #5
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
I've never even heard of this before, where did you read this?
But no, the throttle doesn't cut off when pressed simultaneously with the brakes during heel-toe.
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 10-31-2014, 02:42 PM   #6
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
No problems when I make the downshifts.
tigermack is offline   Reply With Quote
Old 10-31-2014, 02:46 PM   #7
KNS
Says so in the 2015 brochure: 'Brake Override System'
"If both brake and accelerator pedals are pressed simultaneously, the system reduces the operation of the accelerator pedal to help prevent unintentional vehicle acceleration"
I imagine the lawyers came up with this one after people were unable to stop their Toyotas.
Old 10-31-2014, 02:48 PM   #8
gramicci101
Off Topic
It does, but it's not instant. It takes a few seconds, I believe. This doesn't affect heel-toe shifting, and shouldn't affect left foot braking as long as you're doing it right. It's good for people that panic and hold both pedals at once.
edit: http://www.ft86club.com/forums/showthread.php?t=76034
Old 10-31-2014, 02:49 PM   #9
dphan
Drives: Scion FR-S // BMW E36 M3
dphan is offline   Reply With Quote
The Following 2 Users Say Thank You to dphan For This Useful Post:
pche (11-03-2014), samisons (11-30-2014)
Old 10-31-2014, 02:50 PM   #10
STV3
Seρor Member
STV3's Avatar
This is only if the car is in gear. You can rev the engine all you want with your foot on the brake as long as a gear is not engaged.
If you try and do a brake stand, use the brake pedal while drifting, or brake boost (if you're turbo'd) you will feel the engine start to cut power. Unless you do the pedal dance that is.
STV3 is offline   Reply With Quote
Old 10-31-2014, 03:10 PM   #11
KNS
Thanks guys, yeah, I was wondering if the trans being in neutral (for a second) factored into it.
Old 10-31-2014, 03:20 PM   #12
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
No not at all, I heel-toe all the time!
Jolaessss is offline   Reply With Quote
Old 10-31-2014, 08:35 PM   #13
alan.chalkley
Drives: 4wd zooks
The heel/toe downshifts work great in the BRZ.
Only after the ecu finishes it's 100km of learning.
So if the ecu is reset/battery disconnected it goes back to learning.
During learning the ecu causes sluggish throttle blip.
alan.chalkley is offline   Reply With Quote
Old 11-01-2014, 01:39 AM   #14
speargunsandracecars
Drives: 2014 BRZ
I had an NC Miata and heel-toe downshifts are significantly easier on it than the BRZ. I find that the BRZ's gas pedal placement relative to the brake pedal is higher and further apart than the NC's. With the NC, I use the left side of my right foot to brake, slightly rotate my foot so that the right side of my right foot can blip the throttle(AKA lazy 'heel-toe'). But with the BRZ, I really have to rotate my foot to blip. The BRZ takes 'heel-toe' literally. I have since then installed the Cusco Sports Accel Pedal, and it's definitely made heel-toeing much easier, and quicker. Just like it was on my old NC.
speargunsandracecars is offline   Reply With Quote
0-60... at below 3-4k rpm shifts iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 29 08-08-2013 08:16 PM
Honda MTF 06 = awesome shifts!! 001BRZ AUSTRALIA 4 01-07-2013 05:28 AM
Positive Shifts + Bushings laxfogo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-25-2012 12:40 AM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 12:24 AM
you can see how fasts the shifts are in this vid! its quick!!! carbonBLUE Engine, Exhaust, Transmission 24 04-03-2012 07:25 PM
