Drives: 2013 ULTRAMARINE FRS
Several lights came on after changing tyres. Why??
So today I swapped my rear oem wheels for some 13 wrx wheels along with extended studs , spacers and new lug nuts. I used the video provided in one of the forums and did everything the same BUT once finished I turned the car on and my ABS , check engine and traction control lights came on. Do I need to reset my obd codes or did I screw up tremendously? I am a car noob who thought I could work on my frs 🤕 thank you !
Instagram: Roger_Dabbit
![]() This is what I was working with..also the video I mentioned was regarding the extended studs installation Sent from my iPhone using Tapatalk
#3 | |
Our cars have 215/45-17 tires, around 24.6 inch diameter. Wrx is 235/45-17, around 25.3 diameter. Did the lights turn on after you drove? or after you started the car and didn't drive? |
#4 | |
They were on at start up before driving it Sent from my iPhone using Tapatalk
Also thank you hopefully it is just the different wheel size
not playing cards
Did you disassemble the hubs to install the new wheel lugs?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | 86Ryan (08-27-2017) |
If on at start up it isn't the tire size. Check your wheel sensors.
| The Following User Says Thank You to Tcoat For This Useful Post: | 86Ryan (08-27-2017) |
Drives: 2019 Mazda Miata RF
Damaged or unplugged wheel speed sensor would be my guess.
#9 | |
not playing cards
#10 |
You're not my real dad!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#11 |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | wparsons (09-05-2017) |
#12 |
Only because the courts said you have too.
| The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (09-05-2017) |
#13 |
not playing cards
Is that what your mother has been saying? Someday you'll understand why.
#14 |
Hahaha yes I disassembled the hub and put it back together
| FR-S - Changing Lights: Safe to trash signal lights? | Nifty255 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-15-2017 12:00 PM |
| Changing Instrument cluster/HVAC lights? | xFury | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 12-11-2015 01:26 PM |
| changing the dashboard lights? | JoonPrime | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-01-2014 03:11 PM |
| Changing out the door/courtesy lights - problem | mikalem | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 02-10-2014 08:39 AM |
| Changing parking lights to white LED bulbs | JohnAyySays | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 03-13-2013 03:38 AM |
