Old 03-13-2013, 02:45 AM   #1
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Changing parking lights to white LED bulbs
So I just ordered clear side markers and also white LED bulbs for them. In california, does anyone know if changing them to white led bulbs are legal or not?
JohnAyySays is offline   Reply With Quote
Old 03-13-2013, 03:00 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
you only need amber light on the side markers in california
white parking/signal lights is ok though
86_ZN6 is offline   Reply With Quote
Old 03-13-2013, 03:03 AM   #3
JohnAyySays
Alright sounds good! I just purchased 6000k HID Kit and also the LED side marker lights from HIDPowerhouse. And I'm 100% sure that 6000k bulbs are legal correct? I know putting aftermarket HID on any car is illegal though
Old 03-13-2013, 03:05 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
6000K is an aftermarket HID so technically it's illegal.
Old 03-13-2013, 03:08 AM   #5
JohnAyySays
Ooo okay. You think cops around california even care? I've had aftermarket 6000K hids on my old corolla and never had any problems with that. Do you know how strong the HID bulbs in the BRZ is?
Old 03-13-2013, 03:10 AM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
i dont think so. iv been running 6K for 8 years now. been pulled over so many times at night and cops dont say anything
at one point i was running 2 55Watts system
most OEM factory HID are 4500-5000K
Old 03-13-2013, 03:18 AM   #7
DSOmegaX
DSOmegaX's Avatar
Hold on here, as stated by the response, you need amber markers. So if you change to the clear side markers, the light you put inside must be an amber bulb. Sounds like you have both clear side markers AND white bulbs for them so technically your setup would be illegal in CA.
@dsomegax.cars
Old 03-13-2013, 03:18 AM   #8
JohnAyySays
Very nice lol. Thanks for the reassurance! I like to keep everything on my car as "legal" as possible so cops don't have any reason to pull me over.
Old 03-13-2013, 03:23 AM   #9
JohnAyySays
Hmmm I'm not sure what this means but I found this during my research of it:
25950. This section applies to the color of lamps and to any reflector exhibiting or reflecting perceptible light of 0.05 candela or more per foot-candle of incident illumination. Unless provided otherwise, the color of lamps and reflectors upon a vehicle shall be as follows:
(a) The emitted light from all lamps and the reflected light from all reflectors, visible from in front of a vehicle, shall be white or yellow, except as follows:
(1) Rear side marker lamps required by Section 25100 may show red to the front.
(2) The color of foglamps described in Section 24403 may be in the color spectrum from white to yellow.
-When they say visible from the front of the vehicle they also mean the parking lights correct? Because I won't be changing the lights for the turn signals but only the side marker lights to white with a clear side marker.
Old 03-13-2013, 03:29 AM   #10
DSOmegaX
DSOmegaX's Avatar
I remember one of the codes states that side markers must illuminate amber at night, which is what makes it illegal. Since you're putting new LEDs into the side markers anyway, it won't hurt to just get amber ones.
@dsomegax.cars
Old 03-13-2013, 03:32 AM   #11
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
correct! you can change to clear housings, but you need to run amber lights
Old 03-13-2013, 03:38 AM   #12
JohnAyySays
Thanks for all you help guys!(: Just contacted HIDPowerhouse to see if he can switch the white lights I ordered to amber colored ones. Really appreciate all your help!
Side markers & parking lights don't work Cajun Cosmetic Modification (Interior/Exterior/Lighting) 20 05-28-2015 04:28 PM
White LED Turn Signal Bulbs In Stock @ JWM + FREE Shipping JWMotoring Exterior Parts - Lighting 84 03-23-2014 08:07 PM
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 08:39 AM
BRZ Sun Visor LEDs (Or white bulbs) Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 12 11-26-2012 04:57 PM
Fog lights on with parking/running lights possible? BMWDavid BRZ First-Gen (2012+) — General Topics 1 06-16-2012 07:29 PM
