Old 08-26-2017, 10:37 PM   #1
86Ryan
86Ryan's Avatar
Drives: 2013 ULTRAMARINE FRS
Several lights came on after changing tyres. Why??
So today I swapped my rear oem wheels for some 13 wrx wheels along with extended studs , spacers and new lug nuts. I used the video provided in one of the forums and did everything the same BUT once finished I turned the car on and my ABS , check engine and traction control lights came on. Do I need to reset my obd codes or did I screw up tremendously? I am a car noob who thought I could work on my frs 🤕 thank you !
Instagram: Roger_Dabbit
86Ryan is offline   Reply With Quote
Old 08-26-2017, 10:40 PM   #2
86Ryan
86Ryan's Avatar
This is what I was working with..also the video I mentioned was regarding the extended studs installation
Old 08-26-2017, 10:43 PM   #3
swarb
Originally Posted by 86Ryan View Post
So today I swapped my rear oem wheels for some 13 wrx wheels along with extended studs , spacers and new lug nuts. I used the video provided in one of the forums and did everything the same BUT once finished I turned the car on and my ABS , check engine and traction control lights came on. Do I need to reset my obd codes or did I screw up tremendously? I am a car noob who thought I could work on my frs �� thank you !
Probably unlike tire size front and rear.
Our cars have 215/45-17 tires, around 24.6 inch diameter.
Wrx is 235/45-17, around 25.3 diameter.
Did the lights turn on after you drove? or after you started the car and didn't drive?
Old 08-26-2017, 10:47 PM   #4
86Ryan
86Ryan's Avatar
They were on at start up before driving it
Old 08-26-2017, 10:48 PM   #5
86Ryan
86Ryan's Avatar
Also thank you hopefully it is just the different wheel size
Old 08-26-2017, 11:26 PM   #6
Did you disassemble the hubs to install the new wheel lugs?
86Ryan (08-27-2017)
Old 08-26-2017, 11:49 PM   #7
If on at start up it isn't the tire size. Check your wheel sensors.
86Ryan (08-27-2017)
Old 08-26-2017, 11:51 PM   #8
Gunman
Drives: 2019 Mazda Miata RF
Damaged or unplugged wheel speed sensor would be my guess.
The Following 2 Users Say Thank You to Gunman For This Useful Post:
86Ryan (08-27-2017), kch (09-06-2017)
Old 08-26-2017, 11:55 PM   #9
Let OP tell us he pulled the hubs, but yeah...
86Ryan (08-27-2017), Tcoat (08-27-2017)
Old 08-27-2017, 12:16 AM   #10
You're not my real dad!
86Ryan (08-27-2017), Ultramaroon (08-27-2017), wparsons (09-05-2017)
Old 08-27-2017, 12:38 AM   #11
Hey, I pay the bills!
Old 08-27-2017, 12:54 AM   #12
Only because the courts said you have too.
Old 08-27-2017, 01:19 AM   #13
Is that what your mother has been saying? Someday you'll understand why.
Old 08-27-2017, 01:32 AM   #14
86Ryan
86Ryan's Avatar
Hahaha yes I disassembled the hub and put it back together
FR-S - Changing Lights: Safe to trash signal lights? Nifty255 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-15-2017 12:00 PM
Changing Instrument cluster/HVAC lights? xFury Cosmetic Modification (Interior/Exterior/Lighting) 2 12-11-2015 01:26 PM
changing the dashboard lights? JoonPrime Cosmetic Modification (Interior/Exterior/Lighting) 2 10-01-2014 03:11 PM
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 08:39 AM
Changing parking lights to white LED bulbs JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 11 03-13-2013 03:38 AM
