Old 08-20-2017, 07:40 PM   #1
LudwigMiles
Drives: '13 BRZ
Who else has a few rusty screws under the hood?
The engine bay is so clean and new, so these rusted bits really stand out.
I would like to replace them. Does anyone have the same issues?
Next step, is to look up the parts numbers.
LudwigMiles is offline   Reply With Quote
Old 08-20-2017, 07:59 PM   #2
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Just out of curiosity, but where do you live? I live in a salty humid area and have no problems.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 08-20-2017, 08:03 PM   #3
stevesnj
stevesnj's Avatar
He's from NY, typical for that area. Same here in NJ.
My 2016 Build thread
Old 08-20-2017, 08:33 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
It's totaled.
Seriously, why not use some rust remover then give them a lite spray of WD40 here and there?
Old 08-20-2017, 08:43 PM   #5
ls1ac
ls1ac's Avatar
If you are going to clean and coat. Look into Liquid Film, it is lanolin based and is often self healing. It is the new WD40 on the block. We use it on equipment that has to be left outside.
Old 08-20-2017, 08:58 PM   #6
humfrz
DAMN! ......LudwigMiles ...... what you been cleaning your engine bay with - sulfuric acid .......
No. The engine bay on my 2013 FR-S looks brand spanken new (it lives here in pristine Washington).
I'll agree with the above posters, I'd suggest you just clean them up and spray them with a rust inhibitor.
It's most likely just surface rust and won't affect the function of the part - not in your lifetime.
humfrz
Old 08-21-2017, 06:23 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Salt air from the ocean is nothing like salty roads. That salt water spray day in and day out for 4 months gets up into everything and just rots the car out. There's no way to keep a DD clean and unrusty up north. Down here it's easy if you clean it every now and again.
Old 08-21-2017, 08:10 AM   #8
gravitylover
That's not rust! That's NY patina
Old 08-21-2017, 08:37 AM   #9
If I learned nothing else from Antiques Roadshow and Pawnstars I did learn you always leave patina since it makes the item more authentic and valuable!
Old 08-21-2017, 08:58 AM   #10
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Slammillionaire is offline   Reply With Quote
Old 08-21-2017, 11:16 AM   #11
LudwigMiles
Drives: '13 BRZ
What is weird is that only very specific bolts have been affected.
Similar bolts right next to these are perfectly brand new looking.
Yea, instead of hunting down parts, I may just wire brush and Permatex these.
Old 08-21-2017, 11:22 AM   #12
JoeC
Drives: Subaru BRZ Limited
Originally Posted by Slammillionaire View Post
I thought the exact same thing.
JoeC is offline   Reply With Quote
Old 08-21-2017, 12:51 PM   #13
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
My car also came from NY and the engine bay screws/bolts looks just like that; was looking at just replacing them eventually.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-21-2017, 01:15 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
You're right! Question, does a respray count?
Rusty af Porygon Engine, Exhaust, Transmission 32 07-06-2017 11:49 AM
End links are rusty! S84kam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-21-2016 04:30 PM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
Anyone else have rusty nuts? Evil Jesus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-18-2014 11:46 AM
Rusty's GTS finally arrived Rusty86 AUSTRALIA 26 09-28-2012 06:25 AM
