Old 03-19-2016, 08:29 PM   #1
S84kam
S84kam's Avatar
Drives: FBRZS
End links are rusty!
For those looking to swap out springs, please be advised these end links are a pain to remove!
I swapped out my front springs for some pro kits and these 6mm allen key holes just stripped! I had to use vice grips on the back to remove them.
I just checked the subaru catalog and these end links are 50$ each!
S84kam is offline   Reply With Quote
Old 03-19-2016, 10:27 PM   #2
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Thanks for the heads-up. It looks like OP tackled it with the right tools, and even on relatively new car, it's problem.
Any tips from the forum gurus on how to prevent this?
I assume that it's some mix of titanium 6mm Allen keys, litres of PB Blaster, hammer the key into the hex hole, torch the nut, and hit it with an impact socket.
All this seems a bit overkill for a "normal service item." Any chance this is covered under warranty for being unreasonably evil?
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-19-2016, 10:35 PM   #3
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
Standard jap rust proofing. Mine was 3 years old when I swapped out the springs, and had to cut the drop links off in the end. Probably for better to simply replace them with aftermarket adjustables upon changing. Builds in future proofing for further suspension mods later anyway...
secret.squirrel is offline   Reply With Quote
Old 03-19-2016, 11:12 PM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
I just swapped coilovers and swaybars. I had the same problem and they didn't look half as bad as yours. The front ones went out still connected to the original struts and the rear ones when out with the swaybar. Replaced both front and rear with Whitelines.
Tor is offline   Reply With Quote
Old 03-20-2016, 12:20 AM   #5
You can smother everything in grease and keep replacing it every few months.
Your mix is pretty much smack on with the exception of the impact socket.
Warranty won't touch it as it is not a defect.
The same thing will happen with just about any car. Fasteners are untreated steel and they will rust way faster than everything else. Always have and always will. At least the days where the floor rots away in 5 years are long gone.
Originally Posted by Tor View Post
I just swapped coilovers and swaybars. I had the same problem and they didn't look half as bad as yours. .
LOL Welcome to Canada eh where every winter we keep 1,000 salt mines in business even if there is no ice or snow. I think the road salting policy is "we bought it we are gonna use it"
Calum (03-20-2016)
Old 03-20-2016, 06:34 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
What? Salt is dispersed on roads even with no ice/snow on roads?
Old 03-20-2016, 08:24 PM   #7
S84kam
S84kam's Avatar
Drives: FBRZS
yup, if the city doesn't use up its budget by the government new year, the following year the budget will be even tighter!
Old 03-20-2016, 10:09 PM   #8
Mr_Hann
Mr_Hann's Avatar
Drives: 2015 Steel FR-S
You want some OEM endlinks? I have some. 6,000 miles on them.
If you're interested, PM me your zip code
Mr_Hann is offline   Reply With Quote
The Following User Says Thank You to Mr_Hann For This Useful Post:
S84kam (03-21-2016)
Old 03-20-2016, 10:45 PM   #9
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Acetone and type A or F ATF mixed 50/50 works really well and cheap. As the acetone evaporates, it pulls the ATF in..
A PB fan but rust seems to be the Japanese version of loctite redx1000
thomasmryan is offline   Reply With Quote
The Following 2 Users Say Thank You to thomasmryan For This Useful Post:
finch1750 (03-20-2016), S84kam (03-21-2016)
Old 03-21-2016, 04:30 PM   #10
S84kam
S84kam's Avatar
Drives: FBRZS
This is awesome! I just watched a YouTube video and I'm impressed!
Brand New FL Car Rusty Rear Exhaust kairojya Issues | Warranty | Recalls / TSB 7 07-03-2014 11:40 PM
Rusty Rocker Nassty Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-01-2014 07:47 PM
Anyone else have rusty nuts? Evil Jesus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-18-2014 11:46 AM
Rusty exhaust hangers? finch1750 Issues | Warranty | Recalls / TSB 5 11-12-2012 12:29 AM
Rusty's GTS finally arrived Rusty86 AUSTRALIA 26 09-28-2012 06:25 AM
