Old 08-11-2017, 09:31 AM   #1
FRStevan
Drives: 2013 Scion FRS
Valenti 4th light wiring problem
Hello everyone,
So recently I had bought the Valenti tails and the 4th light. My plan for the fourth light was to remove the backing and re-solder the connections so that the triangle only comes on during braking and the V is always on. Following the instructions on the internet I moved the connections but when it was all plugged in only the triangle turned on and it only flashes when I switch my lights on. I tried re-soldering everything back to stock and it still only showed the triangle.
Could this be a result of a bad soldering job? Any tips or help would be helpful, thank you all!
FRStevan is offline   Reply With Quote
Old 08-11-2017, 09:41 AM   #2
Heavyax
Drives: 2015 Ultramarine Scion FR-S
What wires are you tapped into on the brake harness?
Sent from my ONE E1005 using Tapatalk
Heavyax is offline   Reply With Quote
Old 08-11-2017, 10:14 AM   #3
FRStevan
The red wire that came with the $4th light is twisted and taped to the blue wire
Valenti 4th brake wiring problem andrewtgg Cosmetic Modification (Interior/Exterior/Lighting) 14 08-21-2017 08:10 AM
Valenti 4th Brake Light Wiring Heavyax Cosmetic Modification (Interior/Exterior/Lighting) 3 06-11-2017 07:39 AM
Valenti Rear fog light Wiring Question xcooperx Cosmetic Modification (Interior/Exterior/Lighting) 2 08-03-2015 03:03 AM
Valenti bumper light wiring? ANTLAY Cosmetic Modification (Interior/Exterior/Lighting) 3 10-25-2014 05:13 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
