Old 04-05-2017, 11:03 PM   #1
andrewtgg
andrewtgg's Avatar
Drives: Release Series 1.0
Valenti 4th brake wiring problem
I followed this guide on youtube for version 2, [ame="https://www.youtube.com/watch?v=LyQSlMxT5RA"]DIY: Valenti 4th Brake Light Wiring Mod- HOW TO -Separate "V" and Brake - YouTube[/ame]
what i wanted was to split the V and fog and have the fog act as a flashing brake light. I followed how he wired it but for some reason I'm only getting a solid brake light. The only time that it flashes is when i hit the brakes and start and my car. (automatic)
anyone have any ideas what could be the problem? I appreciate any help.
andrewtgg is offline   Reply With Quote
Old 04-06-2017, 01:51 AM   #2
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
EDIT: I'm kinda confused what the problem is.
So for version 2 as described in the video:
1. The "V" stays on with rear running lights (i.e. when you have headlights on).
2. The triangle flashes when you hit the brakes and then remains solid.
What are you trying to achieve?
Do you want the triangle to keep flashing the entire time the brakes are applied? If so, that cannot be done.
PandaSPUR is offline   Reply With Quote
The Following User Says Thank You to PandaSPUR For This Useful Post:
andrewtgg (04-06-2017)
Old 04-06-2017, 02:06 AM   #3
Chronology
Drives: 13' Satin White Pearl BRZ
I had a similar issue. I had to disconnect the long red wire and wire up from a break light connector into the lower break connector, the white. I still don't have my V light up, but I do have the flash x3 then solid on.
I just snipped the super long wire and ran it as a power into the relay. I'll take pictures tomorrow.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
The Following User Says Thank You to Chronology For This Useful Post:
Old 04-06-2017, 02:19 AM   #4
andrewtgg
andrewtgg's Avatar
do you choose to not have the V light up or is that an issue with how you currently have it wired? i'd appreciate those pics. thanks.
Old 04-06-2017, 02:22 AM   #5
andrewtgg
andrewtgg's Avatar
I want exactly how v2 is. V stays on with headlights. Triangle flashes 3x and then remains solid for the duration of the brake.
My problem is that it only flashes 3x when i start up the car. Regular braking only comes out as solid.
Old 04-06-2017, 03:18 AM   #6
Chronology
It's an issue of like to fix. Ill get the pics this afternoon, I have to pull apart a few trunk parts to get to it. I LOVE how something so simple has been a pain
Old 04-06-2017, 02:24 PM   #7
andrewtgg
andrewtgg's Avatar
Did you tap the blue wire into your taillight harness(blue one as well)? That's the one that lights up the V.
Old 04-10-2017, 05:04 PM   #8
andrewtgg
andrewtgg's Avatar
bump. forgot to mention when i brake, the solid light is pretty dim. When i start the car, the flashes happen and its much brighter.
Old 04-10-2017, 08:31 PM   #9
PandaSPUR
PandaSPUR's Avatar
Where did you guys ground to..?
Usually when weird unexplainable electronic issues pop up, its due to a bad ground :|
Old 04-10-2017, 08:53 PM   #10
andrewtgg
andrewtgg's Avatar
theres a ground wire in the harness along with the reverse wire. At this point, i don't even mind having the solid brake light. its just it being dim thats bothering me. When i start the car up, the flashing happens and its way brighter.
Old 05-06-2017, 08:25 PM   #11
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
I get the same issue, were you able to fix it? The dim brake light bugs me so much.
WolF_RS is offline   Reply With Quote
Old 06-08-2017, 12:13 PM   #12
russel619
Drives: Subaru BRZ 2013
Unhappy Any Solution
Has anyone figured out how to get rid of this dimming problem?
russel619 is offline   Reply With Quote
Old 08-20-2017, 04:25 AM   #13
andrewtgg
andrewtgg's Avatar
still no luck. I ended up wiring it up so its solid and now its bright. Did you find a solution?
Old 08-21-2017, 01:07 AM   #14
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Ive only been able to wire up the brake light and V when i press the brake. Still cant get the V to light up with headlights..
Decimus is offline   Reply With Quote
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
Valenti rear fog alternate wiring Gundark Cosmetic Modification (Interior/Exterior/Lighting) 87 09-14-2016 03:12 PM
FS: Valenti RED Tails. Valenti RED 3rd Brake Light. OEM Clear Corners. AngryS13 Exterior Parts (Aero, Lighting, Etc.) 6 08-14-2016 11:35 AM
headlight wiring problem VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 0 12-30-2014 02:41 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
