Drives: 2013 Scion FRS
Valenti 4th light wiring problem
Hello everyone,
So recently I had bought the Valenti tails and the 4th light. My plan for the fourth light was to remove the backing and re-solder the connections so that the triangle only comes on during braking and the V is always on. Following the instructions on the internet I moved the connections but when it was all plugged in only the triangle turned on and it only flashes when I switch my lights on. I tried re-soldering everything back to stock and it still only showed the triangle. Could this be a result of a bad soldering job? Any tips or help would be helpful, thank you all! |
#2 |
Drives: 2015 Ultramarine Scion FR-S
What wires are you tapped into on the brake harness?
Sent from my ONE E1005 using Tapatalk |
#3 |
| Valenti 4th brake wiring problem | andrewtgg | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 08-21-2017 08:10 AM |
| Valenti 4th Brake Light Wiring | Heavyax | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-11-2017 07:39 AM |
| Valenti Rear fog light Wiring Question | xcooperx | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-03-2015 03:03 AM |
| Valenti bumper light wiring? | ANTLAY | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 10-25-2014 05:13 AM |
| Valenti 3rd brake light wiring | SPCorBUST | Southern California | 4 | 09-24-2013 11:57 AM |
