Old 08-06-2017, 03:59 AM   #1
Deisou
Drives: 2013 Subaru BRZ
Tapping Noise After Hard Driving (Video Included)
Hi guys,
I heard this tapping noise from the engine bay after a hot lap at the track when I backed off.
It went on for a about 10 seconds before disappearing. No vibrations or loss of power, just the noise for a short while.
It doesn't sound like it was matched to the engine revs or road speed either.
I did another session and drive the car 2.5 hours to get home afterwards with no issues at all.
Any ideas what the cause of the noise is?
Car: 2013 Subaru BRZ - Stock other than tyres and brake pads & rotors.
[ame="https://www.youtube.com/watch?v=kxIvns9f_Ao"]Subaru BRZ - Brief noise after hot lap - YouTube[/ame]
Deisou is offline   Reply With Quote
Old 08-06-2017, 08:36 AM   #2
ZZT86
ZZT86's Avatar
Drives: BR86
Oil surge @ high G whilst cornering ? You have enough oil in sump or correct weight given how hard you drive & perhaps lengthy sessions ?
ZZT86 is offline   Reply With Quote
Old 08-06-2017, 10:36 AM   #3
stevesnj
stevesnj's Avatar
I'd stop driving it. Sounds like a rod knock. Can you recreate it off track so the dealer can hear it?
My 2016 Build thread
Old 08-06-2017, 11:46 AM   #4
ls1ac
ls1ac's Avatar
As you said it does not seem to be RPM related, it appeared to me it might be speed related. If it is not RPM and you are lucky you may have picked up some junk on your tire and shed it at the next hard corner. (Evan if you are not running very sticky tires someone else may have left a marble.)
Speed related noises are usually tires, brakes, diff, or driveshaft. An other unlikely possibility on our cars is a flapping body panel, but that is normally easily repeatable.
Old 08-06-2017, 01:54 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
It was during that right hand turn. Nothing to do with your engine. Sounds like wheel frequency.
Old 08-06-2017, 02:43 PM   #6
humfrz
Yep ........ "suspension jitters" fer sure ....... not to worry......
humfrz
Old 08-06-2017, 06:27 PM   #7
Deisou
I'm running Redline 5W30 and levels was full prior. It was around 3 minutes of hard driving.
Is there an idiot light or check engine light if there is rod knock?
engine, hot, noise, tapping, track
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
Tapping noise after driving MrAnthonyC Issues | Warranty | Recalls / TSB 2 09-23-2014 01:06 PM
clicking/tapping noise when shifting semi hard Skurge Issues | Warranty | Recalls / TSB 3 09-20-2013 04:37 PM
Strange Tapping noise from under car after use rhood168 Issues | Warranty | Recalls / TSB 10 02-12-2013 02:16 AM
diy request: install a driving camera by tapping power from the interior map light. shaoster DIY (Do-It-Yourself) Guides 6 01-24-2013 02:02 PM
