Old 01-02-2013, 09:11 AM   #1
shaoster
Drives: Toyota 86 GTS Man
diy request: install a driving camera by tapping power from the interior map light.
hi all,
I've recently purchased a front facing driving camera that i'm planning to mount right behind my rear view mirror to continuously record my day to day driving and for security purposes or evidence should it be required. Anyway, the device comes with a Power Safety Device which needs to be tapped onto the car battery power as well as to be grounded, and it prevents the camera from sapping all of the battery power since it is continuously recording.
I have an option to run the power cable all around the windscreen to the fuse box and work from there, but I was thinking if it is possible to just tap the power from the interior map light. Has anyone done anything like that? I would like to know if this is possible, and if so how?
Thanks in advance.
shaoster is offline   Reply With Quote
Old 01-05-2013, 12:22 AM   #2
Techfl3x
Techfl3x's Avatar
Drives: Firestorm Red FRS/86 MT
Would be interested in hearing opinions as well. Would also be curious in your feedback on a front facing camera @shaoster as it definitely is a good idea for evidence purposes.
Techfl3x is offline   Reply With Quote
Old 01-06-2013, 12:15 PM   #3
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
http://www.ft86club.com/forums/showthread.php?t=22915
crazyfrenchbiker is offline   Reply With Quote
Old 01-22-2013, 07:50 AM   #4
shaoster
I managed to install it by tapping it from the stop light fuse via the internal fuse box.
I'm just playing it safe by installing one facing the front. It's been recording quite nicely both during the day and night. This one has a built in GPS and g sensor to save key moments if it detects too much g load (impacts). You should get one
Old 01-23-2013, 03:07 PM   #5
luscious
luscious's Avatar
Drives: 2013 FR-S Argento MT
Here is what i did....it's crude...but simple and effective!
luscious is offline   Reply With Quote
Old 01-23-2013, 09:19 PM   #6
Lokutus
Drives: Scion FR-S AT Asphalt
Any reason not to run the wire through the dome enclosure to the windshield instead of pinching the wire with the dome light box?
Lokutus is offline   Reply With Quote
Old 01-24-2013, 02:02 PM   #7
luscious
luscious's Avatar
There really isn't a lot of force pinching the cable at all. I was just easier this way...only reason why i did it =)
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 01:18 PM
Back up camera integrated with license plate light brianlo622 Electronics | Audio | NAV | Infotainment 10 05-26-2014 09:04 PM
DIY REQUEST - Headers back exhaust install MaXimus DIY (Do-It-Yourself) Guides 2 11-22-2012 11:24 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
