Old 07-30-2017, 02:09 PM   #1
brillo
Drives: 2013 Firestorm FR-S
E85 idle question - occasional surge at a stop
I'm running the Motoeast flexfuel kit on an otherwise stock motor (stock intake/exhaust etc....).
occationally at a stop, my idle (with the A/C on) will bounce upwards from 850ish to 1,000rpm. It doesn't seem to fall down below 800 but you can see the surge upwards on the tach (and my Scanguage). I wouldn't call it rough as its something you see more than you feel (given its not dipping down).
I'm told this is basically normal, is this the injectors cycling to push more fuel due to the e85? My idle didn't do this on my regular 93 tune.
Love the kit and tune, otherwise everything is rock solid and I'm very happy with the power (193whp).
Just curious others experiences, not a deal breaker, just want to make sure I'm not missing something.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-30-2017, 11:20 PM   #2
steve99
Pretty normal with a\c compressor cutting in\out to have small idle variation
Old 07-31-2017, 04:51 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
If AC is switched OFF, can AC compressor still impact readings/logs? (thinking of how to make most consistent results/lessen variables)
Old 07-31-2017, 09:37 AM   #4
brillo
I've tried shutting off the A/C and I occasionally still get the surge. I totally get that the A/C compressor and general idle characteristics mean idle is going to flux 100 rpm or so. Those kinda rpm fluctuations don't even register on the car's tach, but I can see them on my scan gauge.
Jumping up 150 rpm or so seems a little more unusual, which is why I was wondering if maybe I'm seeing something related to the injectors needing to push more fuel at idle on e85 than normal and that is resulting in the surge (could the port injectors be kicking in?).
Its not something I feel as the rpms never fall as part of the process to a level where the idle gets rough.
Old 07-31-2017, 10:03 AM   #5
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Mine does this a little when the AC is running. Doesn't seem to happen with the AC off though.
smg1138 is offline   Reply With Quote
Eibach Pro Kit Bump Stop Question rebsinfx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-12-2016 03:58 AM
SOLVED: Idle Dip only when coming to a stop? spatcha88 Issues | Warranty | Recalls / TSB 38 04-14-2015 12:16 AM
SBD turbo surge?? shif7i7down Forced Induction 72 11-20-2014 09:49 AM
RPM occasional drop with AC on Dboe Issues | Warranty | Recalls / TSB 5 08-15-2014 05:03 PM
Idle issue question Nitesh31 Issues | Warranty | Recalls / TSB 9 09-28-2012 10:04 PM
