Old 08-14-2014, 09:11 PM   #1
Dboe
Drives: 2013 Red FRS
RPM occasional drop with AC on
Trying to figure out why the RPMs jump between 500 to 1000 with the AC on.
I know there is a TSB, but the fix says to re-flash the computer.
I have an OpenFlash and already flashed mine to a different setup. I figure that would have taken care of it.
Thanks for any help. I would have searched the forum, but "rpm" and "ac" are too short of terms to search for.
Dboe is offline   Reply With Quote
Old 08-14-2014, 09:26 PM   #2
nivek111070
Drives: 2014 GB Scoobie BRZ
my ecu was replaced, and my rpm's still drop and it's starting to surge again while in 1st gear at low speeds going through the parking garage
nivek111070 is offline   Reply With Quote
Old 08-14-2014, 09:50 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Google search does the job well.
https://www.google.com/search?site=&....0.w-IFRhx-IxE
Sigh-on-Rice is offline   Reply With Quote
Old 08-15-2014, 02:37 AM   #4
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
normal. It is just the AC power kicking on and off.
l0aded is offline   Reply With Quote
Old 08-15-2014, 10:49 AM   #5
strat61caster
strat61caster's Avatar
Here's why:
The air conditioning needs power to operate, it gets that power by utilizing the engine under your hood. However it doesn't need power all the time so some of the time it's disconnected from the engine, sometimes it's connected and spinning if you ask for it (hit the A/C button, defrost) via a clutch similar to the one in a car's manual transmission. In a low powered car you can feel the loss of power due to the A/C, i.e. an old 4-banger pickup or econo-box (civic/camry), however in modern cars the A/C pump will disengage under heavy acceleration so you get your powah.
In past vehicles and many more mass market consumer oriented vehicles the added load of the A/C is compensated by raising the idle rpm in a way that most people don't even notice a difference when it pops on. Toyota has decided on many vehicles that lowering the idle rpm to the lowest possible level results in better fuel economy and to suffer the consequences of having it too low to effectively be stable when the A/C is kicked on and we get this lovely idle fluctuation when we're sitting at stoplights on warm summer days.
No harm, just a bit annoying and sometimes alarming when it dips too low, several aftermarket tunes/tuners raise the idle rpm to prevent this at the cost of decreased fuel economy.
Old 08-15-2014, 05:03 PM   #6
Dboe
Great explanation. Thanks
Best kit for occasional track usage yomny Forced Induction 14 02-06-2014 08:10 AM
a lot of people like sports cars for looks and the occasional WOT autobrz Other Vehicles & General Automotive Discussions 4 09-17-2013 02:35 PM
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 02:53 AM
Occasional drivetrain thump when putting into 1st gear chaotichoax Engine, Exhaust, Transmission 5 10-21-2012 01:30 PM
Ideal CCW specs for street with occasional track bambbrose Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-11-2011 03:12 PM
