Old 09-28-2012, 05:13 PM   #1
Nitesh31
Nitesh31's Avatar
Drives: Black BRZ Black STI
Idle issue question
So with the idle issue...
I noticed at idle in neutral clutch out the rpms jumped from 600 to 800 and then back down.
Also, the car will shudder a little and go to 700 sometimes at idle too.
Is this the start of the problem? I couldn't find any definitive post on the forum that showed it.
I've got 1650 miles
Nitesh31 is offline   Reply With Quote
Old 09-28-2012, 05:23 PM   #2
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
700-800?? Because 7400 is the stock redline..so if it was idling at 8000 that would be screaming.
However, assuming you mean 700-800, mine does that too occasionally, and i havent seen any issues yet. Maybe someone else who has had the issue can chime in... (i'm a little over 3000 miles with no problems yet...knock on wood)
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 09-28-2012, 05:26 PM   #3
sajonf
Drives: 13 Scion FR-S, 12 Camaro ZL1
Mine usually idles at around 650 rpm. Occasionally I will see it dip to 500 rpm (maybe once every other stoplight). It never goes any lower than that and I don't feel the car shudder when it does this. No CEL lights yet. I have heard others that have had the CEL drop to around 400 rpm. I am sure it is just a matter of time before mine gets worse and throws a CEL.
sajonf is offline   Reply With Quote
Old 09-28-2012, 07:12 PM   #4
Nitesh31
Nitesh31's Avatar
You don't idle at 8000??? The engine gets pretty loud. Jk (edited) but ya I meant all numbers in the hundreds.
The shudder isn't really as bad as what other people have described, it's just a slight bump as if the car is warming up and then a slight increase in rpms.
Well I guess if it doesn't dip down more things should be fine.
So now it's all just a waiting game if a problem should arise...
Old 09-28-2012, 07:22 PM   #5
akuhei
akuhei's Avatar
During those same times, I've noticed I can hear a pump or compressor kicking on, so I usually attribute the shudder to that. Good luck, I'm keeping my fingers crossed that both of us make it through without any problems.
Akuhei's Blog
"Inconceivable"
Old 09-28-2012, 08:01 PM   #6
cruzmora
hey its a fuel pump that needs to be replaced, i took it to scion/toyota of escondido today and they told me that they were going to replace it, apperentaly just a few days ago scion had these changes made. What I did was call toyota 800-331-4331 and then made an appointment with the dealer. When i called toyota i explained the problem, i suggest you do the same, I am talking about that chirping noise when warmed up and idle
cruzmora is offline   Reply With Quote
Old 09-28-2012, 08:38 PM   #7
akuhei
akuhei's Avatar
I havent noticed the chirping...just the idle dip
Akuhei's Blog
"Inconceivable"
Old 09-28-2012, 09:10 PM   #8
cruzmora
oh ok my bad
Old 09-28-2012, 09:37 PM   #9
wheelhaus
wheelhaus's Avatar
the "pump" mentioned above is most likely the AC compressor. It clicks on and off as needed. From what I undertstand, the CEL is triggered when the idle dips too low, for too long. This is perfectly normal if it's only occasional and very brief. However, if there's a problem with the cam timing mechanism or it's control valve, the cam timing gets stuck at the wrong end of it's adjustable timing range and it causes the valve timing at idle to be a little off. Note, the cam is still within it's limits, just not where the ECU thinks it is. This won't cause your engine to explode. If the idle dip becomes more severe and causes the engine to run too low an RPM for too long (enough to shake the car) the ECU triggers a red flag and lights the CEL.
wheelhaus is offline   Reply With Quote
Old 09-28-2012, 10:04 PM   #10
cruzmora
Nah I thought he referred to the chirping idle noise that i was having, but i understand what u r saying
idle
Unofficial - CEL/SL/Idle Issue List for FR-S/BRZ Owners eurospeed Issues | Warranty | Recalls / TSB 3105 05-06-2024 06:47 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle Fluctuation FIX empower-auto Issues | Warranty | Recalls / TSB 2 09-14-2012 02:36 PM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
