Old 07-28-2017, 05:24 PM   #1
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
First start/run with JRSC check my log am i safe?
Just flashed to a Delicious Flash N go
JRSC C38
JDL UEL
I am going to do some data logs for delicious just to check it out but i did a quick data log just to post here to make sure im at least safe to drive.
Car is a bit sluggish down low, not sure if its because i just flashed and the ecu has yet to learn anything..
http://www.datazap.me/u/genruleathum...a=6-8-22-30-33
Better log updated ***
let me know if you see anything off, thanks all.
GenRuleAThumb is offline   Reply With Quote
Old 07-28-2017, 05:55 PM   #2
steve99
looks ok from parameters logged
quite possible it a kind of speed density tune
difficult to tell from logs with limited parameters
looks like they set iam initial to 0.7,( most tuners set to 1 but might be a safety thing for 91 octane), and its climbing back to 1
LTFT look like its been disabled
cannot see any knock
ignition advance looks like what you would expect for FI as does AFR but if 02 sensor has stock scale you cannot see afr richer than 12.17
best talk to delicious guys though
Old 07-28-2017, 06:44 PM   #3
GenRuleAThumb
Drives: 2014 FR-S
Here is a better log from my EcuTek
http://www.datazap.me/u/genruleathum...g?log=0&data=6
Old 07-28-2017, 07:15 PM   #4
armstrom
Drives: none
Flash and Go is a mixed MAF/Speed Density tune. It uses MAF at Idle and low load/revs then switches to speed density at higher loads and revs. My understanding is that they also employ some manner of closed loop fuel control at WOT. Since Ecutek allows for a wide variety of custom maps anything is possible.
-Matt
armstrom is offline   Reply With Quote
Old 07-28-2017, 07:59 PM   #5
steve99
yeah can see some low rpm knock in that log, so it is probably dropping IAM. Deliceous guys will sort it
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
The death of JRSC rotrex 350z Forced Induction 21 03-18-2017 12:15 AM
JRSC oil use xsnapshot Forced Induction 3 03-27-2016 10:22 PM
WTB Used Stage 2 Innovate Kit / JRSC azynneo Want-To-Buy Requests 0 05-26-2015 03:32 PM
Ran into a Red JRSC FRS at Laguna Seca... CSG Mike Northern California 14 08-05-2014 03:39 PM
