Old 01-06-2016, 03:32 AM   #1
350z
Drives: 350z
The death of JRSC rotrex
The stock kit was installed in May and about Sept the HBP was installed along with supporting mods (injectors, pump, e85). The car was probably driven maybe 4K miles with the HBP and ran good until today...
The oil level was still good, belt was aligned properly... While driving, the sound of rocks in a can could be heard followed by a loud high pitch sound then a loud pop from the engine! Car died immediately, all lights came on but luckily it was able to coast onto a close by street.
Opening the hood to inspect I seen greenish fluid splashed around, thinking to myself that's odd since the engine didn't over heat and not coolant lines were busted. Then I seen fluid dripping from under the filter going to the head unit... Took off the coupling and seen this.
The impeller is completely separate from bearings inside as it spins freely (yes the belt is still wrapped around the pulley).
Has anyone else had/seen this issue yet?
350z is offline   Reply With Quote
Old 01-06-2016, 04:59 AM   #2
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
What were the driving conditions before failure? ie rpm, load, etc. Sounds like it's a traction drive failure based on your description. I believe there have been a couple dead blowers mentioned in the JRSC owners thread but not sure if it was the same as your failure. I would suggest posting there.
Have you contacted JR or rotrex about this? Would be interesting to hear their input.
Old 01-06-2016, 08:11 AM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Haven't seen that specifically, but I have seen more than a few failed rotrex SC units.
Freeman is offline   Reply With Quote
Old 01-06-2016, 09:20 AM   #4
350z
Drives: 350z
Same here, just don't like the fact that its not even a year old.
Cruising at about 55ish in traffic, don't know the RPM. I posted in the owners thread but there are trolls in there that like to swing from this brands nuts all day.
Old 01-06-2016, 09:48 AM   #5
Freeman
Freeman's Avatar
Mine lasted about 8,000 miles before it got really loud and boost dropped way off. Impeller was also spinning freely.
Another I've seen was a snapped off input shaft, another internal bearing failure, one other one was the input shaft seizing up and snapping the belt (JRSC).
Old 01-06-2016, 11:46 AM   #6
BigFatFlip
BigFatFlip's Avatar
The unfortunate thing is these aren't rebuildable, so you're pretty much stuck with buying another one instead of replacing a snapped shaft, etc.
Old 01-06-2016, 11:52 AM   #7
Freeman
Freeman's Avatar
Unless there's some sort of warranty coverage. With JR there may be, with my KW issue there wasn't. Had to buy a new supercharger.
Old 01-06-2016, 11:53 AM   #8
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Hi 350z-
Sorry to hear about the trouble with your Rotrex unit.
Have you sent in an email or called? We have not seen anything regarding a broken unit this morning.
Based on the description, this appears to be a Rotrex shaft failure. Shaft failures can happen from a few things, but I'd rather not speculate until we have a look at the unit. We will need to send the unit to Rotrex in Denmark for warranty inspection.
Please call or email us at tech@jacksonracing.com ASAP so we can get the process started. We will need some more information on the unit and system to help with processing.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
Old 01-06-2016, 06:21 PM   #9
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Originally Posted by Jackson Racing View Post
Hi 350z-
-Oscar Jr.
Definitely reach out to JRSC. They took care of me when mine started getting REALLY loud then started making grinding noises. You'll be out of commission for probably 3-4 weeks while the SC gets shipped around so prepare for that. But huge props to JRSC for having both amazing products and customer service.
phanguy is offline   Reply With Quote
Old 01-12-2016, 03:22 AM   #10
EquiFox
Drives: 2014 FRS Firestorm
3-4 weeks ?
Mine got really loud aswell, paid 50% for a replacement while my broken one was being shipped to them and it's been 6 months now, no news (I got a KW kit tho)
Sad thing is that the replacement one started doing the same thing after 2K miles... switching to PTuning turbo
EquiFox is offline   Reply With Quote
Old 01-12-2016, 04:18 AM   #11
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Originally Posted by EquiFox View Post
3-4 weeks ?
Is that only with KW that you had to pay 50%? I don't think JRSC would do that to the people that bought their kits....at least I hope not.
Alltezza is offline   Reply With Quote
Old 01-12-2016, 09:16 AM   #12
Freeman
Freeman's Avatar
No it's a KW thing. Had the same thing happen to me. The blower got really loud, boost dropped way off. Sent it in and was told that Rotrex denied the warranty. Wasn't told the specifics of why they denied it, but that KW was fighting with them on it. I was told I could wait until it's approved or I could buy a new blower for 50% off and get refunded when they approved the warranty claim. So I bought a new blower and haven't heard anything about my warranty claim since. I'm swapping over to Edlebrock when I can afford it.
Old 01-12-2016, 09:19 AM   #13
Freeman
Freeman's Avatar
3-4 weeks ?
I've put 300 miles on my replacement and I'm swapping over to another kit as well. I don't trust the blowers.
Old 01-12-2016, 05:07 PM   #14
EquiFox
Glad to know I wasn't the only one !
I ditched my tuner and KW (worse support ever), dumped 10K on a proper turbo kit, just waiting for summer to arrive :P
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
close. bought jrsc BRZ'13 Canada Classifieds 13 05-29-2015 03:46 PM
WTB Used Stage 2 Innovate Kit / JRSC azynneo Want-To-Buy Requests 0 05-26-2015 03:32 PM
Ran into a Red JRSC FRS at Laguna Seca... CSG Mike Northern California 14 08-05-2014 03:39 PM
CEL Of Death ProTekk Issues | Warranty | Recalls / TSB 41 05-26-2013 11:29 AM
