Old 03-25-2016, 04:20 PM   #1
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
JRSC oil use
I've got a relatively new JRSC (C30) with the HBP. I installed about 1000 miles ago. Install went great, fluid levels were correct.
About 500 miles in I checked the fluid and noticed I was at the bottom of the dipstick. I added until it was mid-range.
Just now I checked it again and my reservoir was again at the bottom of the dipstick. Both times I made sure the car was running and warm when checking fluid levels.
Is this a sign of a more serious problem? I took off the hot side piping and did not notice any oil residue on the inside. I also cannot visually see any leaks, but I can't really see the oil cooler either. (doubt that's the issue..but just FYI)
xsnapshot is offline   Reply With Quote
Old 03-25-2016, 06:41 PM   #2
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
You have to check it with someone revving the car to about 2500-3000rpm. As the revs increase, the reservoir fills up more. That is why if you overfill it, it seeps out the top(even if it doesn't look full).
JDMChris is offline   Reply With Quote
Old 03-25-2016, 09:45 PM   #3
Rotrex fluid or engine oil?
Old 03-27-2016, 10:22 PM   #4
xsnapshot
Fast enough
Rotrex. But... I must confess I had misread my manual. I thought you were just supposed to have the car nice and hot when you checked it.
I went back and checked it by the method described exactly in the install manual and my oil level is fine. (actually it's slightly over filled, but nothing has leaked out).
Lesson learned.
The Following User Says Thank You to xsnapshot For This Useful Post:
CSG Mike (03-28-2016)
JRSC'd GReddyFRS Build Greddy86 Member's Car Journals 10 09-17-2017 03:20 PM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
The death of JRSC rotrex 350z Forced Induction 21 03-18-2017 12:15 AM
close. bought jrsc BRZ'13 Canada Classifieds 13 05-29-2015 03:46 PM
WTB Used Stage 2 Innovate Kit / JRSC azynneo Want-To-Buy Requests 0 05-26-2015 03:32 PM
