Old 07-28-2017, 08:46 AM   #1
radroach
Drives: car
ARP vs Dorman studs
I'm trying to decide which to choose for my wheel stud upgrade / maintenance, ARP or Dorman? Pretty big price difference. Just going for the stock size for install, for oem wheel sizes. Helpful thoughts or comments appreciated.
Old 07-28-2017, 09:47 AM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
ARP are an upgrade, Dorman is an OE style replacement and of good quality.
I stock Dorman studs for my customers who have maintenance issues, and order ARP parts routinely.
ARP studs on my FXT, stock on my BRZ for now.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 07-29-2017, 07:52 PM   #3
RJasonKlein
RJasonKlein's Avatar
What issue are you trying to address by replacing the OEM studs in the first place? I'm not questioning the need to do so in general (I have ARP studs on my car), but I'm basically questioning if you're replacing the OEM studs due to cross threading or corrosion, or because you broke one and need a stronger stud. The bottom line is the Dorman stud is similar to OEM in quality and the ARP stud is of superior quality and quite a bit tougher - you have to choose based on your needs.
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
kch (08-01-2017), radroach (07-30-2017)
Bought winter tires with studs (live in hilly area). Now I want to remove the studs.. redwing634 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-18-2016 08:57 PM
At what point do we need to upgrade head studs and main studs? Amir Ghadiri Forced Induction 5 03-03-2015 11:13 AM
Anyone tried Dorman tmps? RTR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 02-11-2015 08:26 PM
Running different studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-22-2014 01:57 PM
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 11:29 AM
