Old 05-29-2013, 01:27 AM   #1
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Extened Studs?
What else is out there besides ARP? I have two studs on on of the hubs have some damage and I wanted this upgrade so I can have freedom to run spacers for brakes or whatever.
Other quality options? They are a lot more than the $2.17 Subaru charges per stud for stock ones.
http://www.rallysportdirect.com/ARP-...2-2011-WRX-STI
Old 05-29-2013, 01:32 AM   #2
HSC
Drives: Whiteout FR-S
extended studs
I went with the touge factory studs. So far so good...about 15mm longer than stock studs. I read some reviews from Mitsu and Nissan forums and they've run these studs at the track w/o issue. Based on my experience so far, I'd recommend.
HSC is offline   Reply With Quote
Old 05-29-2013, 09:32 AM   #3
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
you need open end lugs with these or no?
dori. is offline   Reply With Quote
Old 05-29-2013, 11:29 AM   #4
BlaineWasHere
Grip>Drift
Drives: FRS
Yes. I would.
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
Spacers / Studs VOID Warranty? N_I_N Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-30-2013 03:32 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
