Old 04-22-2014, 08:03 AM   #1
wparsons
wparsons's Avatar
Running different studs?
Has anyone tried very slightly larger base diameter studs? I know a few local Subaru guys switched to a different ARP stud because they're MUCH cheaper than the proper one.
GM one, fits into our hubs without much drama:
http://www.summitracing.com/int/part...7702/overview/
Proper one:
http://www.summitracing.com/int/part...7716/overview/
The GM one obviously needs a different set of lugs, but if you're buying open ended lugs anyway that's not really a deal breaker, and at 1/3rd of the price for the same quality it makes for an interesting decision.
flickr
Old 04-22-2014, 09:54 AM   #2
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
This isnt something I would be a cheapskate about.... get the proper studs.
Kostamojen is offline   Reply With Quote
Old 04-22-2014, 12:13 PM   #3
wparsons
wparsons's Avatar
They're both ARP studs, the only difference is the thread pitch and a very small difference in knurl diameter.
It's not like the ones for GM are magically weaker, and $150 vs $50 is a big difference if the end result is the same and they function the same.
And like I said, I know a few local racers that do this with other brands as well. They fit 100% fine into the hubs and work great.
flickr
Old 04-22-2014, 01:57 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
One can get Nismo studs with 14.3 knurl diameter, and they would fit perfectly fine on our cars.
Another benefit of using Nismo if one chooses to go down that route, is that Nismo made both 50mm and 60mm studs. 60mm is comparable to ARP, 50mm may work with some spacer + closed ended lugs configurations.
One is not limited to "Subaru WRX-only" stud configurations.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
wparsons (04-22-2014)
I keep breaking lug studs!!! Guff Issues | Warranty | Recalls / TSB 59 12-30-2015 12:34 AM
FS: Extended 12x1.25 studs BlueDubbinTDI Brakes, Suspension, Chassis 9 04-03-2014 10:27 PM
WTB: tires and studs jammz Wheels and Tires 0 02-24-2014 10:29 PM
spacers and stock studs abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-17-2013 10:55 PM
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 11:29 AM
