Drives: WRB BRZ
E85 OFT tune Bucking/surging
Hey all,
Wondering if you can help me out. I'm experiencing bucking/surging at low(ish) RPM and high throttle. I'm running the OFT 2.076 E85 tune. This is my third tank on E85 this season. Last year I didn't notice this at all. I thought I had bad gas at first, but know that I have filled up twice since the switch so I don't think gas is the issue. I'll try to link to a log that shows what is going on. I have good fuel trims and IAM is always at 1.0. Any thoughts or suggestions (or what parameters I should log)? http://www.datazap.me/u/vmax911/buck...zoom=1661-1797 |
#2 | |
Ill say load limits need fixing Also maf scaling It running pig rich when you get on throttle, richer than 11 as that limit of stock o2 sensor scaling The load limits stop it running super rich and very low or retarded timing at high loads low rpm You dont have total ignition tiking in log but i suspect it will be very low or retarded when you get on throttle coupled with rich it will bog |
Drives: Firestorm '13
funny thing is I had this a while ago. what I did was clean my K&N drop in filter and that fixed my bogging issues!. It wouldn't hurt to check the filter.
'13 Firestorm
#4 | |
Drives: WRB BRZ
However, I did find in your OFT tuning thread where Shiv mentioned to slightly lean out the low RPM/High load open loop fueling table. I will give that a shot. Here is another log showing the same issue, this time with ignition timing. http://www.datazap.me/u/vmax911/e85-...6&zoom=387-439 It's never a bad idea to check the air filter, I should have thought of this! Thanks for the reminder, I'll check it out. Last edited by Vmax911; 07-29-2017 at 04:53 PM. |
Drives: 2014 BRZ sterling silver
Do yourself a favor. PM Wayno and send him a contribution and he will send you all his newest Tunes. I'm running his V124 E85 tune and my car is running like a Raped Ape.
| The Following User Says Thank You to oldgunfan For This Useful Post: | zc06_kisstherain (07-31-2017) |
#6 | |
Drives: Toyota 86 GTS
| The Following 3 Users Say Thank You to Wayno For This Useful Post: |
| Horrible bucking and shutter after clutch install | Scikotic | Engine, Exhaust, Transmission | 32 | 07-12-2016 08:10 PM |
| Surging Idle | RichardsFRS | Issues | Warranty | Recalls / TSB | 20 | 03-16-2016 06:47 AM |
| 2-3K RPM hesitation/bucking - logged | 86fun | Software Tuning | 5 | 01-29-2016 08:58 AM |
| Today, my car made a violent bucking sound on start up... | lupindub | Issues | Warranty | Recalls / TSB | 3 | 11-28-2015 09:27 PM |
| loss of power/ bucking in rain | fasteddy | Issues | Warranty | Recalls / TSB | 30 | 10-20-2015 02:08 AM |
