Old 01-24-2016, 08:56 PM   #1
86fun
Drives: 2013 FRS
2-3K RPM hesitation/bucking - logged
Hey guys,
Wondering if anyone with some experience looking at logs and tell me what they think about my log file.
After installing a S/C kit I'm getting part throttle low RPM hesitation/bucking. Even full throttle has hesitation in the same RPM range too actually.
I purposely drove up a slight incline and in a lower gear to help the log show what was happening in a longer period of time.
Notice at about 9 and 11sec the vehicle speed slows, then speeds back up slightly, this is when I was experiencing the hesitation/bucking. All other load points feel smooth.
The calibration used is a CARB tune provided by the manufacturer.
http://www.datazap.me/u/86fun/low-rp...ta=2-3-4-5-6-7
Thanks for any input!
File Type: txt ZA1JB01C_6B 83 4D_Eforce - 23-01-2016 18-06-04.txt (28.9 KB, 137 views)
86fun is offline   Reply With Quote
Old 01-24-2016, 09:19 PM   #2
steve99
Originally Posted by 86fun View Post
Hey guys,
Yep something weird happening the afr goes rearly rich low 11 and the ignition timing goes negitive like -3 with very little change in engine load or throttle position.
Looks like some sort of failsafe trip or something in tune, but this might be caused by malfunctioning sensor or air\boost leak.
Send logs to tuner
Old 01-24-2016, 09:38 PM   #3
pandamancer
Drives: 2015 Scion FR-S 6M Ultramarine
Send logs to tuner
FWIW, I concur. I looked at the log from the Edelbrock post and came to a similar conclusion. Vacuum leaks are where I would start.
Knock looks like it may be another concern. What fuel are you using?
pandamancer is offline   Reply With Quote
The Following User Says Thank You to pandamancer For This Useful Post:
CSG Mike (01-26-2016)
Old 01-24-2016, 10:01 PM   #4
86fun
Drives: 2013 FRS
California 91
Old 01-28-2016, 01:31 PM   #5
devtec
Drives: 2015 Subaru BRZ Limited
I have the exact same problem... having the car checked for vacuum leaks today. will keep this thread updated.
Anyone else with the Edelbrock s/c having this problem?
devtec is offline   Reply With Quote
Old 01-29-2016, 08:58 AM   #6
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I did not have this issue when on factory CARB tune from Edelbrock.
NotSoJDM is offline   Reply With Quote
Today, my car made a violent bucking sound on start up... lupindub Issues | Warranty | Recalls / TSB 3 11-28-2015 09:27 PM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 02:08 AM
Logged Track Time Datasets Needed for my Web Project! :) Zamyatin Scion FR-S / Toyota 86 GT86 General Forum 7 02-11-2015 01:59 PM
RPM hesitation on WOT? Yamajee Issues | Warranty | Recalls / TSB 8 01-10-2015 12:43 PM
Stay logged in? frz06 Site Announcements / Questions / Issues 2 06-13-2014 03:03 PM
