Drives: 2013 Pearl White 6MT
Surging Idle
My idle is surging from 1grand to 500. Does it when I'm parked and when I'm at a light with clutch depressed and car in neutral
Anyone else have this problem |
Drives: 16 FRS
I've seen this posted before but I'm not quite sure what the solution is.. I'm driving a 16 frs with maybe 4000 clicks on it.. and it's done since I pulled it outta the show room
Sent from my SM-G900W8 using Tapatalk |
Ahh well it might be normal. I read some articles where its an ecu problem and Toyota will re-flash but mines a 13 with 46k on it. I do have an extended warranty.
#4 | |
Seriously. Search. There is a sticky on top of this section for tsbs. And a many threads on this subject. http://www.ft86club.com/forums/showthread.php?t=21868 |
I saw the sticky. 15 to 16 models
Mines a 13. Guess I'll check the vin anyway |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Is your AC or window defroster on?
Heater was on, but no defrosters. Chilly this morn but it did it last weekend and it was in 70s. TSB says occurs after 25 minutes or more of highway driving then stopped. Also tsb is automatic mines manual
Not Bаnned Anymore
Okay cuz I know when it blows any air to the windshield it puts AC on to dry out the air so it doesn't fog, even if the heater is on and that might have caused it. Its highly unlikely but you may also have a super small vacuum leak after the MAF sensor?
#9 | |
SEARCH ![]() S-SB-0040-13 : Intermittent RPM Drop Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2013 – 2014 FR-S Introduction Some Scion FR-S vehicles may exhibit an engine RPM drop while idling with the A/C off. The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) logic has been revised to address this condition. Use the following repair procedure for ECM (PCM) reprogramming. |
#10 | |
The other ones are specifically for automatics......
#11 |
#12 |
The Fail Boat
Drives: CWP S.B.
Surging Idle
My car does this sometimes too, live with it or get real good gas.... Doesn't seem to do it if I just put some octane booster in.. But probably just placebo effect. LoL
Mine is 15 & I complained to the dealer & there was not thing they can do since my ecu/pcu is obvious on the new firmware already... Sent from my iPhone using Tapatalk |
#13 | |
Contract? /人◕ ‿‿ ◕人\
#14 |
Site Moderator
Drives: ichi 86 Project
Play nice or I'll make you guys play nice. It's up to you.
ichi |
| Idle dip | yomny | Software Tuning | 38 | 06-14-2016 05:54 PM |
| Idle at 4 psi? | LS1M | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 07-18-2015 12:01 PM |
| K&N idle dip | Dominus | Engine, Exhaust, Transmission | 7 | 01-28-2015 10:17 PM |
| AFR @ Idle | woode | Forced Induction | 12 | 01-19-2014 08:38 PM |
| Odd idle | jbixel | Issues | Warranty | Recalls / TSB | 2 | 11-02-2013 08:35 AM |
